Re: Drilling glass - yes *LINK*
JohnKJordan in East TN
>Bill,
You can drill a hole in glass with grit, as mentioned. It's been a long time since I tried it, so I drilled a 1/16" hole in the side of an old mason jar. (I better throw it away now before my wife cans some more pickled okra!) Instead of a wood dowel, I used a short piece of brass rod chucked in a drill press. Even better would be a piece of brass tubing. Aluminum should work as well.
My drill press at the slowest possible speed was still faster than I would prefer but it worked. For grit I used automotive valve grinding/lapping compound with a drop of oil added to thin. I applied fairly light pressure, enough to hear the grinding. Repeatedly lifting and lowering the "bit" helped to bring more grit to the tip of the rod. I stopped and flattened the rod a couple of times since it was rounded off quickly. A tube should work better.
Note that you will get chipping on the inside as you break through unless the glass is backed up firmly.
Although this method will work, it's pretty slow. A blunt end diamond drill bit is far easier.
diamond drill bits
