OT FM Antenna
OT FM Antenna
OT FM Antenna
Mike Cunningham (Cape May NJ)
>Is anyone using an FM antenna for a radio in the shop or home? If so is it an internal, external, fixed direction or multi and, if it works well, what brand and model?
I have a terrible time with FM reception in the shop so end up listening mostly to CDs. On the radio I listen to NPR which comes in fine but there are several jazz stations that I can't pull in though I receive them clearly in my vehicle throughout the area.
Thanks for any help.
MIKE
Re: OT FM Antenna
Re: OT FM Antenna
Allen Neighbors
>Mike, back before Childress had an FM station, the closest station I could get in the house or auto was 60 miles away. Couldn't get it in the shop. I just stretched some speaker 2-wire along the eave of my shop... about 40 feet long... tied the ends together, cut one of the two wires in the center of the length, and ran another pair of wires to that from my radio. It worked well. I have no idea where I came up with this... probably from my Army days.
Re: OT FM Antenna
Re: OT FM Antenna *LINK*
John M in Mid Mich
>As I understand it, 40ft is probably way overkill. I think you get about all you can get from a "1/2 wave" length, and that works out to be about 1 meter. You might check out the link I've added. The audio web sites I visit regularly point to this site.
John
FM Antennas
Re: OT FM Antenna
Re: OT FM Antenna
Brian Hahn in SW Wisconsin
>Funny you should ask. I'm planning on installing an FM antenna for my shop. It will be an external antenna mounted on a short mast about 30' away from the shop. We had a bit of snow and ice this past weekend, so it might be spring before I can do it.
Re: OT FM Antenna
Chuck Engstrom
>I put up a Winegard HD-6010 two months ago. About $23 at a local wholesaler found through mfg's webpage, see link.
The 6010 is two elements crossed for non-directional coverage, very simple to install on a short mast. The HD-6000, about $65, is 4 elements, directional, which is fine if you have a particular direction to point at and don't mind the extra expense. The 6010 is doing OK for me, about 20 miles from Baltimore, but I could do better with the directional 6000 and a rotator (even more $$$) to get Washington, Philly, etc.
Best--
Chuck Engstrom
Winegard FM antennas
Re: OT FM Antenna
Re: That's a classic dipole design.....
Jamie Donaldson
>.... and should work well, but can be fine tuned to a wave length that is shorter.
Re: OT FM Antenna
I use internet radio and have given up
Jerry Hall
>trying to receive stuff over the air. I just plug my laptop into the stereo auxiliary or my Ipod with downloads. It drives me crazy that my truck radio gets far better reception in the garage than the radio right next to it. Have hooked it up to a tv antenna, and the little dipole strip that came with the stereo, and a powered antenna. Is their something about a truck chassis that helps reception?
Antenna's along with skews are the instruments of the devil. I am 30 - 40 miles away, 3000 feet above, the stations in the flatlands below me. I give up.
Re: OT FM Antenna
Jerry Hall
Re: OT FM Antenna
Serious Satellite
>I live too far from any decent radio stations so I went with Serious satellite radio.
Re: OT FM Antenna
Thanks
>Thanks for all of the replies. I'll start with the simple wire antenna and if that fails, go through the list. None appear to be overly expensive.
While I generally enjoy NPR, I do need the occasional break to music. Thanks!
Mike
Re: OT FM Antenna
Re: Serious and XM Satellite
Bill Hale / The Wood Spinner
>The nice thing with these is if you get the portable type you can move them to your vehicle. I have XM and it is so nice to have radio all over the country with no dead spots. They also have anything you want to listen to.
Bill
Re: OT FM Antenna
Hey, Mike how about....
Clem Wixted
>...using an unused car radio running off of a 12 v battery. Plug in an unused car antenna and a couple of speakers and you will have good reception. Auto radios have a good front end which is why you get such good reception. On the other hand, most home radios are built for a few dollars and therefore you can't get stations that are more than a few miles away without an external antenna.
If you don't have a spare car radio I'll bring one of mine when I visit you sometime next year.
Clem
Re: OT FM Antenna
Rabbit Ears..worked for me!
Ron Bauman
Re: OT FM Antenna
Lan Brady
>Serius 65 for me!! 24/7
Lan
Re: OT FM Antenna
Re: Hey, Mike how about....
>Thanks I'll stick to AC
Re: OT FM Antenna
Re: OT FM Antenna
Bob Macgregor
>I used to use flat TV lead for the antenna and the 1/2 wavelength suggestion is good. Alternatively, get a set of TV rabbit ears and use them (they are a lot more adjustable, too); the regular broadcast wavelengths are contiguous with the FM band.
