>The Black Oak was piling up, and my sister up in Washington state loves her oak furniture and knickknacks. I turned a 5x12 salad bowl earlier, but yesterday had an idea to make some multi axis handled serving set. So here is the result.
>The spoon and fork are oak also. I had it labeled "Valley Oak" but who knows. The blank was about 3 x 16. Cut into a long "T" with the handle about 1-1/2 square.
- Put as much of the handle as I could into 2 jaws of a big Vicmarc long nose chuck.
- Rough turned the handle and made a pommel at the spoon,fork end between centers
- turned the bottom 40% on center
- turned most of the top angled off center to create an angle that seemed suitable for an implement
- turned the end on a third angled center to create a comfortable way for it to nest into the palm of my sisters hand, and for interest. Made the two ends different so my sister could tell the difference between a fork and a spoon (: Don't tell her I said that.
- Used a French curve to layout the shape I wanted, band sawed and cleaned up with a stationary belt sander. Hand sanded. Watco. Then walnut oil after full drying to maintain.
I did "flat" work for the spoon end so I could preserve the mass for tail stock support while changing centers. May experiment with smaller scale fully turned items. Should be doable off center to create a shallow curve within the spoon/fork. But it wouldn't be any faster, and I am not sure it would be a better design.
It felt good to have an idea at the end of the day, just before cleanup, and then have it turn out so quickly.
