Pneumatic power sanding
Bob Macgregor
>My electric drill collection is slowly shrinking as I burn them up sanding. Has anyone switched to a pneumatic sander? Does this work OK, without making the compressor pump run too much? Are there drawbacks to doing this than I haven't thought about?
I'm eager to hear the voice of experience on this.
BOB
Re: Pneumatic power sanding
Steven Antonucci
I do
steve antonucci
>I have a cheap right angle air driven tool that I jack the compressor pressure up and can run for a bit before it needs to run again. It will obviously depend largely on the size of your tank... mine is 26 gallons.
Steve
Bill Hale
>I use an angle die grinder from Harbour Freight. There are several available so check on air usage. I believe the one I use is only 3 cfm. You can get them on sale for about $ 14.00 and at regular price about $ 19.00.
I use an angle grinder for very rough stuff, $ 35.00 and the air for second stage with 3 " sanding discs. You must be carefull on the die grinder as they are very high speed and can get pretty aggresive.
I use the regular Sioux offset drill with 3" discs for the fine work. The offset drill should last a long time as a touch up only tool.
Good turning and be safe
Bill in CG, AZ.
JohnKJordan in East TN
>Do you have any trouble with oil? The die grinder I use spits oil mist out vents near the front which I might not want on my turning.
Stuart Johnson
>I use a Grex ROS. My compressor isn't large enough to get the full benefit and it does cycle very quickly. I will normally run it until the compressor kicks on and then use it as a passive sander until the cycle ends. I have just kept right on sanding with no problem but the noise starts to bother me. I've never kept it up but I doubt if the compressor would be able to catch up and shut off with the sander running.
robo hippy
>I experimented with a pneumatic Sioux angle drill. It works fine. There was a bit of water coming out, but this was cured by wrapping a cloth around the vent. The air could pass through, but the oil and water wouldn't sputter onto the wood. The draw back is that the compressor would run continuously (60 gal Campbell Hausfeld). I figured that the angle drills would use a lot less electricity than the compressor. Also in the summer it adds a lot of heat to the shop. I just keep getting the angle drills rebuilt. Last one got about 350 or more bowls before the bearings gave out. Am now at 250 for the current incarnation. Am trying some fancy engineer recomended bearings to see if it makes any difference. 3 inch discs, and slower speed (600 rpm via a 1/4 inch piece of cork under the trigger).
robo hippy
Steven Antonucci
Yes and no...
steve antonucci
>Yes, it spits oil. No, I don't have any trouble, since I wrap the bottom in paper towel to catch the oil. Also, a little protection against Boyle's Law.
Steven
Bob Macgregor
>Thanks for the feedback.
I'm not sure which way I'll go on this. Drills are so cheap, that maybe I should just keep replacing them as they burn up. Of oourse, there are other uses for a compressor...
Heck, I'm still trying to figure out if I can adapt my central vacuum to vacuum chucking. If I burned it up, I'd definitely be persona non grata around the house!
BOB
Bill Hale / The Wood Spinner
>I never have. I also don't remember how long it has been since I oiled it. Guess I better do that ! Thanks
Bill in CG, AZ.
>Thanks RH for the cork idea. I have always had a problem keeping the speed down.
Bill
Vince
>Hi Bob,
If you are talking about using a Random Orbital Pneumatic Sanders I can tell they draw more CFPM then most other air tools. I also do not highly recommended one for use with the lower grits such as anything under 280 grit. I believe a drill such as a Souix or Milwalkee(sp) works much better with the lower grits. I do use ROS for my higher grits 280-320 and higher. If one choose to go with a compressor(oil less)this application makes the compressor work much to hard and you will degraded the life of the compressor greatly. A compressor 60 gallons and higher is what is needed if one plans on using ROS and that come straight from Campell Hausman a major compressor manufacture. I talk more about this on my site if you care to look. www.VincesWoodNWonders.com under Sanding Suggestions. Hope this helps.
Vince
>Just my 2 cents worth. I bought an air sander. My compressor is 26 gallon and runs constantly until it gets too hot so I don't let it do that. This is a cheap HF sander which might be why it's so air hungry. I also hate the whine. Perhaps a better quality sander would solve both problems.
I bought a $60 Dewalt standard drill after burning out 3 or 4 Black and Decker $39 drills. I've been using this for 6 years and hundreds of turnings. So far no problems. I keep looking at the Souix angle drills but they are so expensive and don't sound like they last as long as my drill.
Lan Brady
>Bob,
I use the 2" grex ros sander. I turn the pressure down to 40psi. I can sand for about 5 minute before tripping on my sears 30 gal tank compressor. The sander is listed as 2.2 cfm and the compressor is rated at 4.0 cfm. I am not a professional so It is not 8 hrs a day!
Lan
