Sealing the inside of peppermills?
>I'll be making some peppermills for Xmas gifts (and some salt shakers too).
Do any of ya'll put a sealer coat on the inside? If so, what do you use?
No sealing needed
Dominic Greco in Richboro PA
>JL,
I've made dozens of peppermills and have only sealed the first couple. It's really unnecessary unless of course, you're using some kind of super toxic wood that shouldn't be used in the first place (for instance say,...poison ivy!). :>)
Any finish that you put on that will wear away as the peppercorns move against them. Peppercorns (or more exactly, the peppercorn hulls) are some of the most abrasive things around. I used to work for a company that did all the pneumatic conveying piping at McCormick Spices. When you serviced the cast iron after some time had past, it was polished like a mirror. But work down like you would not believe!
See ya around,
Dominic
Agree
Mike Cunningham (Cape May NJ)
>I absolutely agree with everything that Dom says. However, to keep the end user happy (Some feel that a finish is a necessity to protect them..go figure)I apply sunflower oil just so I can say that there's a finish in there. I plug one end, pour it in and slosh it about.
Another idea, prior to the oil I run a shotgun bore brush though the mill to clean it up a bit.
Mike
Re: Thanks...
>Though I don't quite have a bore brush of that caliber! Now if you said 30-06 or 0.50, I could comply with that :). I'll use some walnut oil or sunflower oil to "wash" it out.
