moisture meters
moisture meters
moisture meters
Carol - now in NC Nebraska
>Any of you turners use them? Or am I better off with a digital postal scale, brown paper bags, and a DNA bucket?
Re: moisture meters
Re: moisture meters
George Van
>Carol, I use a Wagner pinless electronic moisture meter when necessary. I have it for lumber use and therefore I can double its use. I also have a balance scale left over from or bakery. I use this more to monitor the drying weight of the item. When it stops loosing weight it is ready to use or move to a dryer environment if a lower moisture content is necessary.This is as helpful and as the moisture meter if I did not already own a moisture meter.
Re: moisture meters
Re: moisture meters
Barbara Gill, Remlik VA
>I too have moisture meters I use for lumber; I rarely try it on turning stock. I would never buy one for turnings.
Re: moisture meters
Re: moisture meters
Carole Valentine
>I have one. I never use it for turning stuff. I don't bother with the scales either. I can pretty well tell with my hands if a piece is ready to finish turn. Sometimes I'm wrong, especially if I am impatient to finish the piece, but not too often.
Re: moisture meters
Re: moisture meters
russ Fairfield
>I use a very crude moisture meter. I always drill out the center of a piece of wood, and immediately stick my finger in the hole. If it feels dry, it is. If it feels moist, it is. Works every time and hasn't failed me yet.
Another way to tell the wood moisture is to grab a handful of shavings, and squeeze them in your hand. If they feel just warm, the wood is dry. If they feel warm and moist, then the wood still has a way to go and we can treat it appropriately. With a little practice, we can tell whether the wood is dry, slightly moist, a little moist, moist, very moist, or wet; and that is close enough for most woodturning.
Another moisture meter for exterior surfaces is our cheek. Yep, that part of our face. It is the most sensitive part of our vody to temperature. With the wood at room temperature, if it feels cool on our cheek, it is still moist. If it feels neutral, neither warm nor cool, then it is at equiligrium. I would guess this is accurate to within 1% moisture content because it is close enough to tell me whether a tightly fitted box lid will still fit the same way tomorrow or next week.
If you think I'm nuts, that's OK too. I will just go on squeezing the shavings.
Re: moisture meters
ebd
Re: moisture meters
ebd
>I've got a cheap pin type from Woodcraft and I use it a lot. I check my roughed out green blanks till they bottom out. More importantly I check supposedly dry blanks of very expensive exotic stuff. You might be surprised how many times a "dry" blank had a reading of 20-30. Right now I am trying to dry some lilac without splitting. I'm following the moisture on that very closely. Not so much the actual reading but the rate of change.
Re: moisture meters
Re: moisture meters
>I'm with Russ on this. Give it a kiss. Touch it to your cheek or just give a little kiss. You will know.
I like his other tests too.
I have the postal scales and moisture meters and they are fun to play with for about a minute, but don't really have a lot of entertainment value. Perhaps they are good for training your cheek.
Re: moisture meters
Russ mooning the neighbors?
>God I'm glad you clarified that statement. I had visions of you mooning the neighbors. :) Russ I'm confused about your drilling out the center. I do that on hollow work of course but never do that on bowls. When do you drill? Is this a bowl blank? I rough turn my bowls and there isn't anything left to drill. I seem to remember one time that you said the best way to save wood was to cut it into bowl blanks. Is that where this comes in. Thanks John
Re: moisture meters
Re: Russ mooning the neighbors?
Niles Ruth
>Thanks for the mental image, John. : O
I did get a chuckle at Russ's sticking his finger in the wood to see if it's wet. : )
Like most woodturners, I've never used a moisture meter, if the wood is heavier than I think it should be, it's still too wet.
Carol, are you getting a lot of wet wood? Do you have a place to dry it evenly and quickly? like an old fridge or tight cabinet?
Re: moisture meters
Re: Cheeky meter
>I like it, Russ. I'll do it. Sure is less expensive than meter.
I finished a bowl yesterday and wanted to start on a box, but decided I didn't have anything dry enough. So far the wood I have collected has been a bunch from Indy Fest. Thanks Ray and Terry. And some form John Hart that I bought. It was wet when it arrived and it is all wrapped in Saran wrap, and pretty heavy. I am not sure how I would go about drying it faster than just waiting it out. Anything I pick up around here would be wet and not ready to turn before I have to pack all this up and move it to Arizona (next August).
What to do? What to do? I'd like a real cedar 4x4 to practice box making. But all the lumber yards carry are pith centered treated posts. Yuck!
Meanwhile I will turn the be rough turned bowl blanks I got from Terry. Pictures later. Promise.
