Re: I think the peavey is more versatile, no?
JohnKJordan in East TN
>There is a thing called a log jack made specifically to roll and lift a log. I have one but find it more trouble to use than worth it. If the log is short, it's hard to control. If the log is large diameter, the log jack I have can't get a grip (the one I have is smaller than my cant hooks).
I find it just as easy to trim a small log by lifting it off the ground with my foot. I either roll a large log onto a branch or something to get it off the ground a bit, or most of the time I don't move it to trim - if you hold the chain saw horizontal it will stay out of the dirt and the last tiny bit next to the ground can usually be broken off with a kick, or if not, touched carefully with the tip of the saw, again, without touching the dirt. BTW, in the woods I try to lay the log down on branches as I limb and buck to keep it off the dirt.
I don't have any experience with the peavey but I'm having trouble visualizing how a peavey can easily lift a large log off the ground. If you grab it with the hook and pry back towards you, seems like the spike would just sink into the ground rather than lift the log. I suppose you could just pry it with the point, but I carry a separate steel pry bar on the truck for that.
What do you want to use it for? Bucking a felled tree in the woods, reparing and loading logs onto a truck or trailer, slicing up logs to prepare for woodturning, ???
If you haven't done so, maybe you can try out the various tools before you spend a lot of money (none of them are cheap). A local saw mill or tree service company may have these and let you play.
