Two skew chisel questions
wilbur
>I've been practicing using a skew after watching Alan Lacer's DVD's, and I'm pretty happy learning to use a skew chisel. It's a lot easier than I thought. But I found that there are some things that I am doing that are different from what I see in the videos, and I was wondering if I am doing something wrong.
First, Alan Lacer seems to do all cuts with his right hand on the handle, and his left on the blade of the skew chisel and on the tool rest. I find that for making cuts going from right to left this seems to be very comfortable, but instead of repositioning my body to make a left to right cut, I find it easier just to switch hands so that my left hand is on the handle and my right is on the blade and tool rest. Does anyone else switch hands when switching directions?
Second, the video teaches making a V-cut with the long point of the skew, and making rolling cuts for making a bead with the short point. I actually find it easier to roll a bead with the long point. My thought is that a rolling cut is just a V cut in an arc. Maybe the short end of my skew just needs to be sharper. But does anyone else make a rolling cut using the long point of the skew?
In any case, Alan Lacer's two skew chisel DVD's are just great.
Re: Two skew chisel questions
Tom Minehan
>I am by no means a master of the skew but I use my skew's as you do. I am learning to turn "left handed" when going left to right. I'm not yet comfortable doing it but I force myself to do it and the practice is beginning to show. I also use the long point down when turning beads. I had not really thought about turning left handed until I spent a day with Bill Grumbine and he convinced me that it was the way to clean up the outside of a bowl when the bottom is mounted in a chuck.
Carol - now in NC Nebraska
>I also switch hands. FWIW.
No experience with skews yet. The Lacer DVD awaits.
There's no "right" and "wrong"
Ruth Niles
>I took a one-day lesson with Nick Cook on efficiency in production turning. The only turning involved was techniques, I switch hands Nick doesn't. I could turn almost as fast as he did (actually no one can ever turn as fast as Nick does!) so I figured why bother changing. There's no body adjustment or tool rest or more moves involved with one way vs the other. So you're doing it the right way. Sometimes I switch hands just because the knuckles on my right hand will hurt holding the handle too long.
Point up or point down really doesn't matter either IF you have the control, are comfortable and get the results you want. Someone else will get major catches your way and you might get major catches his way. I watch very closely when someone is demoing with the skew and have picked up a few excellent techniques but they weren't in any book so you just might be starting a trend here! : )
Enjoy it.
I love the skew, have Alan's and adore them but also have the straight grind, a 1/4" round rod (thank you, Ed Moore), a 2" straight (ugly and mean looking Sears tool), and they are all terrific for various jobs.
>I switch hands also. I am not a master of the skew and Intend to get better with it, but there are two issues here, speed and proficiency.
Proficiency being the ability to make the cuts smoothly and easily without stress on you and without catches. If you can use both hands and cut matching shapes (symmetrical beads, etc.) go for it.
Most of us are right hand dominant, some of us some much so that we would not even try to do something left handed, so that is why it is taught that way. About 7% are left handed and even fewer are ambidextrous. Consider yourself lucky.
Speed for a production turner is important. The time it takes to switch hands or tools is important to someone turning a hundred balusters a day, but matters little to most of us. (There is a guy in our turning club that is a professional production turner for a local mill shop. He can turn a 24" baluster for a porch rail in 7 minutes, using only a skew. It's jaw dropping to watch him. OTOH, he got an order for 320 pieces. I would have said Just shoot me. He actually did them twice, a few years apart, because the first set were ruined during the installation and they rotted.)
I took a class from David Ellsworth, he seemed pleased with those of us switching hands.
I took another class form Richard Raffin (name dropper). He demonstrated the mechanics of a catch. Did it over and over. Said that if you don't understand why a catch happens and can't do one on purpose, you don't know what to avoid. So, as far as toe or heal, just learn where those catches are and avoid them.
Long or short point
Ken Grunke from SW WI
>I usually find it easier to use the short point for rolling a bead, as it only involves a twirling motion of the skew with just a bit of handle swing. But the long point works well for beads smaller than an inch diameter, for the same reason.
To say it another way, if you turn a large bead with the long point, you have to swing the chisel in a larger arc than with the short point. A matter of economy of motion.
Re: Long or short point
>I agree with Ken. I use the short point for turning beads but will sometimes change to the long point to touch up a bead that is large and has parallel sides. I fell I have more control of that deep cut that way.
I switch hands a lot but tend to turn most of my beads with my right hand. I chuck up a piece of scrap and practice with my left hand and it's getting pretty good but I don't trust it yet for serious projects that I can't screw up.
I use the toe or long point to cut V cuts and to finish off the bottom of goblets or to finish of square corners.
As Ruth said, whatever works for you is the correct way.
keith zimmerman, Normal IL
>I am somewhat ambidextrous and am able to do almost anything with either hand. In turning, I switch hands with not only the skew but with other tools as well. I also use the skew with the long point down 99% of the time, including rolling small beads. This is just the way I found working with the skew easiest and more comfortable.
I have never taken a class with anyone about the skew, but have watched the DVDs and many demos. After the first demo I saw in my club, I just picked it up and forced myself to learn the tool.
keithz
