CA glue turns white question?
>I have been using whatever CA glue Woodcraft sells for years. I usually hit it with accelerant, especially when I rub sawdust into a defect and soak it with thin CA. (not a strength issue). Lately the CA has been cooking off and turning white. I stopped using the accelerant and waited for it to set on its own. That seemed to help. But, yesterday I used thin CA to fill a hairline crack in a piece. I wanted to reinforce the crack. I put tape down both sides and put the CA in, letting it soak into the crack by capillary action and left it. After about ten minutes it looked fine and I removed the tape. This morning the crack is white. (it was inside the house, not in the cold shop) Any suggestions?
Re: CA glue turns white question?
Don Evans
>Don't have the definitive answer for it, but no matter the brand CA always seems to turn white if I use accelerate process.
Moisture will also accelerate CA so I wonder if that was the culprit on your wood or in the wood?
Don
Bill Howatt
>I've never had "white" problems other than when using accelerant.
First thought is that glue has gone old or is contaminated. Does it do it on all "repairs" or just on a particular piece of wood; could be there is something in the wood that causes a similar reaction as the accelerant. It is known that the drying/curing time of CA is influenced by various factors including moisture. Is the wood wet?
Try some patches on other materials (if you haven't).
Bill
>The wood is walnut. Old, air dried walnut. It had been in the unheated shop for months, then finished with Deft, then in the house for several days. I spotted this while I was finishing it and decided to "reinforce" it by soaking the crack with CA. Since it turned white, I wonder if I strengthened the crack at all?
Another good reason not to try to make a silk purse out of a sow's ear.
russ Fairfield
>CA Glue turn white from 2 things. Heat and water.
CA glue cures by an exothermic reaction, and there is some amount of heat given off even when it is allowed to sit there and react without an accelerator. The heat from a rapid acceleration of the curing process makes the glue boil and the foam is formed.
Moisture in the wood will be absorbed into the glue as it cures, and that moisture is driven out of the wood by the heat that is generated duribng the curing of the glue. Any wood has some moisture in it, remember equilibrium moisture will be somewhere around 8-12% in most locarions. As the wood is heated from the glue reaction, equilibrium is disturbed, and there is available moisture released from the wood to be absorbed by the glue.
The solution to the first is to not use an accelerator. The solution to the moisture is to seal the wood with lacquer before using the filler. The diller is just as strong, and the lacquer seals the moisture in the wood so it cannot be absorbed bu the glue.
eaglesc
>The PH level also affects the accelerating(heat) process.
CA will not adhere to wood fumed with muriatic acid yet seems to "instantly bond" to woods like ebony.
Barbara Gill, Remlik VA
>I use the accelerator all the time and rarely does the glue turn white, even if I soak it. I really think the quality of the glue is part of the issue. I use Star Brand CA from California. They advertise in American Woodturner.
When Carole Valentine was here last, she noticed the difference.
Correction *LINK*
>The glue is Star Bond.
Star Bond Glue
Re: Correction
Bill Hale / The Wood Spinner
>I have used Star Bond for years and seldom have any problem. I have never had a fill material turn white. As stated it will boil with accelerant but that is on top and not in the crack. Water will turn it white if sprayed on the glue.
Try ordering from Star Bond and see if that solves the problem.
Good turning and be safe
Bill in CG, AZ.
Allen Neighbors
>I have had CA turn white in a crack when I had previously used the Lacquer wash on the piece. This has happened on different types of wood. Now, after applying the Lacquer Wash, I always blow the excess out of the crack with a blast of air, before I apply the CA. It hasn't happened since.
