sanding with wax as a lubricant
Carol - now in NC Nebraska
>I just saw Mike's box where he noted that he sanded with wax as a lubricant.
I just did a bowl that wanted to crack while I was sanding. Don't know the species.
So what grit and what wax?
Mike?
Re: sanding with wax as a lubricant
Allen Neighbors
>Carol, some folks use wax with all grits they go through. I've never used wax for sanding, but if that's what it takes to make a piece look as awesome as that __?__ Rosewood Box that Mike posted last... I'm gonna try it. I loved the look of that.
I think Wally uses Johnson's Paste Wax... but I may be full of it. It would probably a good one to try.
I usually sand without a lubricant, but once in a while, I get a good piece going and I'll sand with Danish Oil beginning with 220 and going on through 4-600 grit.
Mike Stafford
Mike Stafford
>Hi Carol. I am not sure why your bowl started to crack. Was it green wood that was drying too quickly and started to crack? Bowls may crack for different reasons than boxes that are turned with the grain running the length of the box. The grain usually runs perpendicular to the lathe bed in a bowl while it is parallel in the type of box I have pictured.
The reason I use wax on some of my boxes is because they are very dense oily timbers. Sanding dense timbers on the end grain like the box I have pictured can result in heat checks. These are caused by sanding at too high of a speed on the lathe, sanding with dull sandpaper, or sanding too long with paper that is too fine. This is particularly true when the end grain becomes thin like on the top and bottom of a box. To avoid this I will sometimes use a paste wax to sand with cleaning the surface between grits with mineral spirits. I will clean the surface after the last grit I use and buff up the finish on the lathe by increasing the speed and using a piece of shoe shine flannel. I am not sure if this is of any benefit during bowl turning.
Carol, the cracking problem on your bowl may not be related to this at all.
>The wood was really dry. The grain wrapped around the rim 180� in places. I tried to glue in back with CA, but more sanding and it just cracked again. Not enough surface to hold, I guess.
Anyway, the bowl is still whole, crack or no, and it launched three times while I was trying to reverse mount it on a jam chuck. Once it hit the floor hard and I thought that it was a goner. Nope. Still hanging together. Currently it is drying. Sometime tomorrow I will buff it out and take a picture. Woo-hoo!
I got the wood from Terry Daniels at Indy Fest, so I hope he will identify it for me.
And then....a BOX!
Mike Stafford
Mike Stafford
>Wow, Carol, sounds like you are having quite an adventure with your forays into turning. Please be careful. I hope you are wearing a face shield. A launched bowl is nothing to joke about if it hits you in the right place. I saw one guy get hit right between the eyes and when he awoke he did not want to turn anymore for a while.
Wally Dickerman in Arizona
>Carol, The fact that your bowl cracked while sanding had little or nothing to do with using a sanding lubricant. If the cracks are surface checks it is caused by friction heat. It also indicates that the wood is still wet. Certain woods are more prone to surface checks than others. To help eliminate surface checks you want to eliminate heat. This means slowing down the lathe, moving the sandpaper over the surface more, and do not overuse the the paper. When the surface of the paper has become quite smooth it's been overused and friction will cause more heat, plus it tends to burnish the wood, which isn't good.
If the cracks are large it's probably just wet wood that is prone to crack. As you may remember, I always have a large number of rough turned vessels in my shop that have been rough turned wet, waxed with Johnson's wax, and left to dry. If you finish turn wet wood you need to turn it to a uniform thickness and bag it for future sanding and finishing or get a finish on it immediately. As you know, some woods are more prone to crack than others, so you need to keep that in mind. If you're turning a piece of mesquite it's not nearly as apt to crack as a piece of apple wood.
Often when wood cracks it's because the crack was already there but perhaps not visable. There's nothing that you can do about that.
Wally
Mike Hamilton
>Hi Carol,
Maybe that was Terry Quiram with the truck bed full of blanks and wood?
How are things in Husker land?
Regards,
Mike Hamilton
Plainfield, IN
>Mia culpa.
You are right!
Thanks, Mike.
>LOL!
The first time it went under my arm and bounced off the floor. The second time it hit me in the tummy and fell to the floor. The third time I caught it.
It is very light.
I learned tons with this one and I will post more about it when I post the picture. I think it will survived buffing. :)
Well, practice makes perfect, doesn't it? And to think I had a bowl gouge in my hand instead of a catcher's mit.
But seriously, you are right about face protection, Mike. I have two face masks, both in Arizona!
Carol, your face is worth a 3rd safety mask
Eddie Pacheco; San Jose, Ca.
>Heh,heh, I originally used "3rd face mask", but it doesn't read nicely..:-)
>I learned about moving the sandpaper more smartly after the crack developed. I also had the lathe too slow, hence too much dwell time with the sandpaper. Ramped things up and sanding went much better and a lot cooler.
I use sandpaper as you taught me � as if someone else was buying it. :)
The blank was turned wet by Terry Q. (not Daniels, mia culpa!) and it was quite dry and very light when I got it. There was no protective coat of anything on it. Terry will have to weigh in on the species and how long ago he rough turned the blank.
Now that some gel varnish is on it, it is hard to see the crack. Since it is the first bowl I have turned without someone standing at my elbow, I am unlikely to foist it off on someone else. Maybe the next one for a Christmas present. :)
Re: Carol, your face is worth a 3rd safety mask
>You are right, Eddie. I'll have to get one.
