>or anyone else who cares to chime in. I have a dozen pieces in the finish process. The wood has been sealed. I've been applying an oil finish that has been giving good results. The last coat that was put on earlier this week has not dried, but is now sticky.
1) Does Oil finish go bad all of a sudden?
2) Should I wipe the pieces down to remove the sticky?
3) Should I bother with thinning the finish or should I chunk it and get a fresh bottle?
>Hi Rev, Sometimes oil will not dry and becomes sticky,best way I have found to remedy that is to apply more oil and wipe it dry.The new coat will soften the previous one and can be wiped away.Also you might try applying the new coat and then wet sanding it,then wipe it dry,let set a few days and then buff it,works for me......
>Doug, it would help if we knew what kind of oil, what kind of wood, what you sealed it with and the temperature where you are finishing. Is your finish starting to gel or does it look just like it did when you first opened it?
>We ar entering that time of the year when cold weather and old oils start causing finishing problems.
Oil works best at 70F. Lower temperatures than that, and the cure starts getting slower. Those liquid molecules just stand there and shiver rather than grabbing each other to form the larger solid molecules.
Old oil cures slower than fresh oil. This was not a problem in warm weather, but it soon becomes a problem as the temperatures start to fall below 70F.
Old oil may not look any different from fresh oil, and it can be old long before a gel starts to form on the surface. When I lived in North Florida, I found that any oil that had gone through one summer heat cycle should be condidered as "old" and replaced.
Do what Mac suggested, but you might consider getting a fresh can of finish, and moving the wood inside the house while it is curing.
>Works for me. This bottle is right at a year old. It was outside during the summer buy has been in the basement ever since. Wasn't as bad as I thought it was, but I did go out and get some new finish this afternoon.
>So Russ, if it's the temp that's causing my oils to be sticky, is there a way to warm up the object to promote better "hand holding" amongst the oil molecules?
>You can start bt not putting and oil finish on cold wood. Bring the wood in the house and let it reach room temperature before taking it back out to the cold shop to apply the oil finish. Then bring it back inside again.
If your water heater is inside the house, put the wood under a paperboard box on top of the heater while it cures. Under a box with a small light bulb works, as does covering the box with an electric blanket
