Hunter Tool Screws
Hunter Tool Screws
Hunter Tool Screws
Bill Kram
>Drat, there was a posting on the sizes of the metric screws used for mounting the carbide cutters & I misplaced it. Does anyone recall what they were? I think the #1 unit used M4x0,45? Would like to verify that & find the sizes for the larger units.
Thanks for any help
Re: Hunter Tool Screws
George Van
>Hey Bill, Mike gave me the information Below:
#1 cutter ... use a # 1 screw, M2.5-0.45 tap, T-7 torx wrench
#3 & #4 cutters ... both use # 4 screws, M4-0.7 tap, T-15 torx wrench
Bill Kram
>George & Mike,
Many thanks for the info
Bill
Texian
>Bill,
The M4-0.7 needs a #30 tap drill size. Don't know about the others. Was pleasantly amazed to find both drill and tap in our local hardware store.
>You can find the screws and taps at MSC but shipping may get you. I found the taps at my local Radio Controlled toy shop. I would rather buy the screws from Mike because I know exactly what I'm getting. As mentioned earlier the taper on his screws matches the taper on the cutters. This not only locks them in place better but also keeps from cracking the cutter which is quite hard and could be easily broken with a screw with the wrong taper.
When you look at how long these cutter last the price of the cutter and screw divided over the life of the tool makes it a bargain.
