>Julie, there are a couple of woodturning videos on youtube also. Search woodturning. The ones by Blair Davis and JT something are pretty good. It is pretty hard to put in words but pictures say alot. My local library has several videos. You might check that out also.
>a scraper? My Oland tool cutters are called scrapers by most turners, but they are cutters, if you grind and use them properly. You use them just like you use a bowl gouge.
On a piece that is already rounded: If you are going to cut from right to left, hold the gouge with the cutting edge at about a 45 degree angle to the surface, with the flute rolled ever so slightly to the left. Allow the bevel to touch the surface of the wood, then roll the flute farther to the left, slowly, until the edge begins to cut. Sort of like using a skew, only much easier. After a few cuts, you'll be able to find the "sweet spot", and you'll be going great guns in no time. Unlike the skew, with a bowl gouge most cuts are made with the cutting edge closer to the nose, rather than the heel.
Sharp tools are required when you cut green wood... (course, dry wood likes sharp tools, too). When I'm cutting green wood, I turn up the speed, and take as deep a cut as the law allows, til I get close to where I want the shape to be, then lighten up a bit. If you consistently sharpen the bevel the same, finding the 'sweet spot' will become automatic.
I second the suggestion that you view some videos... I've got Bill's video and love it... but if you can get another turner that's close enough to you to come over and show you... that would be best... hands on training.
You need some hands-on instruction. Perhaps you can find someone who lives close enough to you here on WC. If you are a member of AAW, you can look in your Resource Directory to hopefully find someone nearby. If you are not a member of AAW, I would strongly recommend that you do that right away.
Don't worry, your tools will work just fine when you learn how to use them, and how not to use them.
>Don't beat yourself up. The first roughing cuts are just that�you're wasting the wood away that you don't want. When you start the shaping and smoothing cuts is when you want to make the smooth cuts. Keep sharpening your tools as you go and you'll get there.
The advice to watch Bill Grumbine's DVD will help a lot. In the meantime do the best you can and you'll still come out with something usable. All of us feel like throwing rocks at our early work but that's the learning process and very necessary. You'll get there....Ron
>I second both the YouTube and library suggetions. Also, you will find that you have to watch these several times and then come back to spot-check later when you run into a snag.
Lacking the opportunity for personal hands on instruction, I agree with the other posters on the purchase of a DVD. While you wait for Santa, you could search the net for pictorial tutorials on turning. I have included a link to one I came across on turning a simple bowl.
Also, www.woodturningonline.com has several beginner articles (even a Bill Grumbine pictorial on roughing a bowl blank). Just click on Turning Articles in the upper left corner of the home page for a listing. Some are for pay, but most are free.
>Julie, Phillip's link is an excellent tutorial but finding someone to give you some hands on help is still the best. While it's been mentioned to you several times, you don't tell us where you're located and there might be someone near you that would offer to provide some hands on assistance. For the listing of the AAW chapters check here to find the one nearest to you. You'll find lots of help there.
I echo Cyril's comments on hooking up with a local AAW chapter. Looking over previous postings, it appears that you are located in Charleston, SC. There is a local AAW chapter there.
Also, there is a local WoodCraft store in Charleston. I checked their class schedule and they are offering an introductory bowl turning class tommorow (Dec. 1) and another on January 5.
I tend to hold the gouge handle lower than what is shown in the picture you sent, causing the overall angle of the tool to be more upright. This seems to take a less aggressive cut by exposing the cutting edge at a shearing angle (I am just guessing here, but I probably hold the bottom of the tool at 30 degrees from vertical, say maybe 4 o'clock). Also, you could try rotating the grove in the gouge slightly where it points more away from the wood. Again, less aggressive cut by exposing less of the cutting edge to the oncoming wood. Conceptually, this is hard to pick up in words, but can be instantly felt when someone shows you how. I know you are hearing this a lot from us.
Did you check out your local Woodcraft class schedule? I know that tomorrow's class may be short notice. But the hands on help would be great if you could take advantage.
>Better yet, contact Sorby directly and ask them to send you their FREE turning video CDs. There are 3. The first one, "Starting Woodturning", is where the video at the link is from.
The second one, "Specialist Turning Tools Part 1", is a great one as well. Part 2 is the third. Since they're all FREE, get them all.
The videos on the Woodcraft site have been substantially compressed and reduced in resolution, making it just that much harder to see what is being done.
If you are computer savvy, I think Sorby may even have the ISO image of the entire disk available on their site, which would be quicker than ordering the disks.
>Julie, everyone has given you great advice. I only have a couple things to add, One is stop being afraid of the wood, when I started, every catch was a heart stopper! Now I hardly notice them except when I get one at the finishing stages of a piece, then most of the people within a 1/4 mi. notice. The other thing is don't be timid, make a cut! Keep the tool rest close to the piece and go for it. The pic with the gouge turned almost 90deg. and pulling up the grain looked like a catch looking to happen, ride the bevel and try to cut down-hill. In the meantime, think of a catch as a learning experience. Hope I helped a little.
