REAL MILK PAINT
Beall Buffing System- How to?
Eric Knutsen
>I recently set up my PSI version of the Beall system. I polished a hollow vessel with moderate results..... I think I may have been a little stingy with the amount of Tripoli, White Diamond and Carnuba. Can anyone suggest how much I should "load the wheels" with. In my woodturning club I have seen finished pieces with absolutely spectacular results..... Any suggestions?
Re: Beall Buffing System- How to?
Re: Beall Buffing System- How to? *LINK*
Julie
>http://www.woodcraft.com/family.aspx?familyid=2036&mode=videos#tabs
here is a video link to see how to use the system..
Beall System How To Video
Martin Harris
Martin Harris
>I had the same thoughts today while using my Beall for only the second time. The video and instructions are a bit vague, to say the least. I also wondered about how hard to polish.
But I'll hazard a guess that it all depends on the type of wood. So we should keep experimenting!
Martin
Re: Martin and Eric, it all does depend
Allen Neighbors
>on the finish, and the wood.
First off, I'll tell you what I was told. Turn on the buffer, and it will take only about one second to load the medium... just a swipe across the wheel. You don't want to load the wheel too much... it'll make a mess of things... transfering the medium to the next wheel, etc.
Some people don't buff Black Walnut wood with White Diamond... they skip that step. I buff Black Walnut with White Diamond... but I make sure the pores of the wood are sealed, so the White Diamond doesn't fill them in.
When you buff with the Tripoli, if it's bare wood, don't worry about how much pressure you put on it. If it's a built-up, polymerizing oil finish, or if you have finished it with Lacquer or some other Varnish-type of finish, if you pressure it hard, you can melt into the finish and have to do the finish over, in addition to picking up the finish on the wheel.
Buffing will not alleviate bad sanding habits. You don't want to try to buff wood that isn't sanded s-m-o-o-t-h... underline that word... every scratch will show through for sure, except for the tiny, superficial ones which m-i-g-h-t be removed by the Tripoli step.
You can clean your wheels with an old sawblade. I say 'old' because it will dull the blade quickly, if it wasn't already dull when you started. :) I use an old saw from a cheap miter box.
Maybe someone else will chime in here with some useful info. :)
Troy German
>It doesn't take much effort to put too much compound on the wheels. I keep a piece of scrap wood next to the lathe when I'm buffing. After I load the wheel, I "buff" the scrap piece until it stops imparting color.
Troy
Barry Elder
>It doesn't cost much to call Beall's 800 number and get advice from some of the most helpful people around. (No offense to the great people of WC!) Also, since you have made your own system, you might want to experiment with how much loading of the wheels will work for you. Start with the tripoli and White Diamond very lightly, then go a little heavier, etc. When you get the finish you desire, clean the wheels and you more or less know how much loading to do.
Randy G
>Great link Julie, I had never seen that. Thanks
