Needlework
Richard Jones
>OK, does anyone make "laying tools" for needlework folks? If so, could use some tips and pics.
Thanks.
Rich
Needlework
Richard Jones
Thanks.
Rich
Re: Needlework
Ed Davidson (Colorado Springs)
>Rich,
I had some requests for laying tools a while back and here's what I came up with. These measure about 5" to 6" long. The ladies seemed to like them.
Best regards,
Ed D.
Re: Needlework
Allen Neighbors
>Glad you posted the pic of them. I never heard them called 'laying tools', so I didn't know what they were.
I've always heard ladies refer to them as a 'stilleto'... they're used to maneuver material close to the needle when sewing with a machine.
I've probably made twenty or so of them for all the ladies in my wife's quilting club, but instead of making the point in wood, I insert a large needle into the end of the tool, leaving about 1-1/4" sticking out. I CA the needle into a 1/6" hole that I drill into the end. Don't have any pics of them.
They'll also sell at craft shows... but you'll have to explain to most women what they are for. :)
Those are sure some nice looking ones!
Thanks for posting this thread!
Re: Needlework
Richard Jones
>Thanks guys, appreciate the help.
A needlework lady explained to me that a laying tool is used to separate/untwist/etc/. the threads before they're snugged up so that they are uniform in appearance.
Biggest problem for me is parting off. To do the point, I part off on the ball end, then put the whole works in a collet chuck, protected by some masking tape. Point the end, apply some finish.
Just wondering the correct technique on these, or if there is one........:)
Thanks again.
Rich
Re: Needlework
The MountainMan
>I used to make ka-jillions of these "rug hooking hooks" .. Stuck different crochet needles in one end. They really sold at rug-hooking fairs and hooking schools!! Also were considered "eye-candy" for lots of hookers... One day a lady stopped by my table - just could not believe her eyes!! How do you paint them so nicely?? I told her "with lots of big woodworking equipment!! (nah! I told the truth!! I am too sick with lymphoma these days to get out in that cold wood shop and do much of anything!! I keep thinking
"one day!!)
Regards
The MountainMan
Re: Needlework
Stuart Johnson
>Rug hooks are the only thing I ever sold. They are easy and cheap to knock out but in my opinion just plain boring. I now make things like the hooks, seam press, laying tools and seam rippers for little stocking type stuffers. Anyone that does craft shows would probably sell a bundle of them.
my technique for thin spindles
JohnKJordan in East TN
Richard,
I don't know if there is a better technique, but when I turn thin spindles with finished ends such as sharp points (hair sticks, etc) I hold the wood in a chuck. (Actually, if possible, I turn a short morse taper and use the headstock spindle as a jam chuck - this gives more working room and prevents working tight around a spinning chuck). If using a jam chuck or if the piece is long (over about 7" or so) or if the wood is weak or the grain is not straight and clear, I support the other end with the tailstock, otherwise it's just held at one end. (Tip: I always make a small hole in the tailstock end - this centers nicely and avoids splitting brittle wood.)
I shape and sand everything but the point, shaping the headstock end down to a small diameter (1/4" or so). I always work from the far end and keep the headstock end thick for as long as possible to reduce vibration.
I apply finish to everything but the very ends (often with Mylands friction polish for gloss). Then I thin and cut the point while supporting the rest lightly with my left hand. When the point is shaped and cut free, I may touch it up with sandpaper (possibly backing the tailstock a bit out of the way if needed) and apply finish while continuing to support the stick with my left hand. It's nice to leave the tailstock close since it can help support the hand that is playing the part of a steady rest.
Then, if the piece is long, I continue to support it with the left hand and part off at the headstock end with the skew (one-handed). If the part doesn't lend itself to parting with the skew (i.e., not enough room), I thin at the headstock with a parting tool (to 1/8" or less), stop the lathe, cut off with a fine saw, then whittle and finish the end by hand. (Never let it break off or it may pull fibers out of the end.) It's amazing that such a tiny toothpick will continue to drive a long spindle at high speed if the other end is supported!
Re: Needlework
The MountainMan
>$25 each cash provides me with lots of incentive!! I can stand there and nock those little guys out all day long!! The custom hooks plus the oak frames and stands that I also made and sold, bought most of the woodworking equipment in my workshop.
Regards
The MountainMan
Re: Needlework *LINK*
The MountainMan
>Hey!
Have you ever looked at this guy's work?? My wife has several of his crochet hooks... I decided I was not going to learn to hand-make the hook end for 3 or 4 hooks!!
Regards
The MountainMan
Turned Treasures
Re: Needlework
Stuart Johnson
>That takes more stick to it than I care to take doing something I don't enjoy. I agree at $25 is an incentive. My top was $35 for a Blackwood hook but most went for between $15 and $20. I don't have any idea how many I could have sold if I kept on but like I said I don't enjoy turning them. Couple that with a dread in talking / hearing when dealing with people it just wasn't worth it. Anyone that does craft shows is missing some sure income if they don't turn these small items.
Re: Needlework
That guy is amazing. It was his web page at got me started on turning gavels a few years ago. Perhaps one day I'll be skilled enough to try a hat. Wishful thinking.
Re: Needlework
The MountainMan
>Hey Stuart!
Yeah! You are either born with "gift of gab" or you just have to develop it!! I lived in a vacume until I was around 30 - then I started running around with a bunch of old guys - they give everything and everybody "heck!!". Always in fun and jest - I adapted very easily into the fraternity after I became un-shy and saw how the group operated!! It will come with age!! I get a real 'kick' out of talking to people!! If you talk to them, they will talk to you!! And they will buy your product!!
Regards
The MountainMan
