Veritas - Innovation in Tools
Preserving the natural edge
Martin Harris
Martin Harris
>These are my first attempts at natural edge turning. Both are from the same 7" log, hence the squatness. They are sanded but have no finish applied.
What can I use to preserve the very thing, silver bark? (It's already mostly peeled off the first one.
Comments and critiques very welcome.
Martin
Re: Preserving the natural edge
Glenn Hodges, Nashville, GA
>Nice work for your 1st NE job. I use thin to medium thin CA glue on mine to insure the bark's stability. I would turn the bowl upside down when applying it to prevent the glue from getting on the wood, and then lightly spray accelerator. When you do another one try and find a wood which will have more contrast between the sap and heart wood, and make the bottom smaller. Good luck you are off to a great start.
Allen Neighbors
>Glenn gave you a good response, Martin. Here's another tip for hanging onto the bark before you finish the shaping: After you get through the bark and into the wood, all the way around the bowl. Apply a light wash consisting of 35%Lacquer/65%Thinner just to the bark rim and the wood that is next to it. Then, blow that with a blast of air to get the excess wash out of the way. Let that cure for about 3 or 4 minutes. Then saturate the bark rim, down through the cadmium layer with thin CA. I think it might penetrate better than the medium. Let that cure, and you're good to go. If I'm out, and in a hurry, I buy the CA at Walmart... Loctite brand. 3.96 per bottle.
Way to go on your first NEs! You are indeed on your way! As Glenn says, don't sacrifice the shape just to save some wood. :)
Keep it up. :)
Martin Harris
Martin Harris
>Jim and Allen:
Thanks for your advice, kind words, and encouragement. I'll cut bigger piece tomorrow and keep at it.
Martin
Thanks...
Rick Urban
>I use CA along the cambium layer, too, Martin, and here are a couple of additional related thoughts...
First, there is greater chance of success if the tree is cut when the sap is down. When the sap is flowing it forms a fluid boundary along which there is more of a tendency to separate. It is sometimes really tough to keep it intact otherwise.
Second, while one normally wants to cut "downhill" with respect to the grain (small to large diameter with face grain orientation) it is often better to cut "uphill" where the bark edge is concerned. That is, cut from the mouth side of the bowl toward the foot so the bark edge is supported by the unerlying sapwood fibers.
Remember not to hurry and make fine cuts because the bark is weaker and it's easy to put too much pressure towards the center of roation when you're cutting air. That can result in too big a bite when the bark comes around again which chips out a chunk.
Hope this helps some. Enjoy!
Rick Davenport
>Martin,
That's a great start to the tricky process of natural edge bowls!
If you want to make the bark on the low sides the same thickness as the tops, then make a more graceful curve on the bowl sides.
Look at the bowl on the left.
The profile of the side is flat, then curves in rapidly to a flat bottom.
If that curve more closely follows the bark curve just above it, you will lose the extra bark thickness on the low sides.
I hope that makes sense.
Also, you might like the wider bark, and if you do, ignore what I just wrote.
Rick
