Slow speed grinder
Slow speed grinder
Slow speed grinder
Don in Central Illinois
>I purchased a slow speed grinder from Woodcraft and am thinking about buying the Wolverine system. Will my Ellsworth jig work on the Wolverine without much adaption?
Re: Slow speed grinder
>Yes I added a block to my wolverine bar to create the proper dimensions to use the Ellsworth jig. I just followed the dimensions given on the Ellworth jig and put a ruler in the V block of the Oneway arm to measure the height needed. Then I made a wooden V block that sits in the Oneway jig. I put that in when I want to create the exact ellsworth grind.
>Thanks. I believe that I can even do that. I'm thinking of taking the afternoon off and might have to go out of my way home and stop by Woodcraft.
Russ Babbitt
>I copied the adapter used by David. Basically it is just a block of wood that raises his jig up an inch.
