What kind of drill bit?
Stuart Johnson
>I want to drill some borg type of rod for tool bits. What type of drill bits should I buy? I know this probably sounds like one of those stupid questions that slow down the earth rotation but in the past I have never drilled anything harder than Mesquite.
Re: What kind of drill bit?
>Stewart. Just a standard twist drill bit like you buy from the Borg. Not a spade bit, brad point or forestner style. I use 1/4" holes for a 3/16" square HSS bit. SometimesI have to just barely knock off the corners of the square bit to make it easier to insert in the hole. I just use the grinder to do that. If your in doubt drill a test hole in another scrap of metal and try the bit.
JohnKJordan in East TN
>Stuart,
You can drill unhardened steel with any HSS twist drill bit.
If you haven't drilled metal before: Use a drill press with slow speed. Make an indentation with a center punch or something to keep the bit from wandering. You can use nearly any oil as a cutting lubricant - you don't need much, I usually just squirt some on the drill bit and let it drip down to the tip. The shavings are hazardous.
gtwilkins
>Stuart,
Also use a wooden "V" block and clamp everything to the drill press table if you don't have a machinists vise, do not try to hand hold rod as it can get away from you with nasty results.
Trevor
p.s. don't ask how I know this!
Re: What kind of drill bit?....Thanks everyone
Stuart Johnson
