Big Thanks from Small Turner-Long
Don Orr
>I�d like to thank a couple of well known turners for sharing their knowledge and skills with me. A bit of background-I was turning a natural edge Magnolia crotch bowl last night. It came out reasonably well, but I had some trouble along the way. This is where the generosity of turners came into play. I spent a couple of days with Bill Grumbine recently at a nearby club. Had a great time. For the hands-on day, I chose to work on natural edge bowls. I showed Bill a couple of bowls I had done and the problems I was having. He showed me some techniques he uses and it helped me a lot. Thanks Bill ! I used these techniques to work on this bowl and it made quite a difference. That is until I got it too thin and tried to go back up to the rim which now flexed all over the place. Now I had terrible ridges and grooves all over and it was still wet and very flexible. What to do? I remembered a demo by Clay Foster a few years ago at Totally Turning in Albany, NY where he showed how using a card scraper on a bowl or vessel can help get rid of torn end grain. I tried this technique on my bowl and it worked great ! Thanks Clay! I used a curved scraper on the inside and a straight scraper on the outside. Outstanding results. I still need to sand the bowl after it dries but it looks pretty good already.
So thanks very much Bill and Clay! I do pay attention and sometimes I actually remember. And thanks to all the other turners from which I have learned so much, many of whom are on this board!
Re: Big Thanks from Small Turner-Long
Lan Brady
>Don,
Great story, thanks for sharing.
I have never heard of using the card scrapers.
Is the lathe running?
Lan
Ooops !
Don Orr
>Wow, forgot an important point-the lathe is NOT running in my case.
Re: Ooops !
Lan Brady
>thanks
Roger Smith
>Len, I will use the cards with the lathe running on all except natural edge.
Re: Big Thanks from Small Turner-Long *LINK*
JohnKJordan in East TN
I use these scrapers often, especially on soft wood like e.red cedar and on torn end grain. I used one this afternoon on the inside of a small end-grain goblet. I once did a piece with just cabinet scrapers and no sandpaper just to see if I could do it and it came out OK, although not as slick as 600 paper.
I usually use the scrapers with the lathe on, hand held (never with a tool rest). I'll usually scrape inside and on particularly torn places with the lathe off. I use flat scrapers on the outside of a bowl. I cut the end off one curved scraper to get inside things better, both for turnings and carvings (pic below).
The set of small curved scrapers (I got mine from Highland Hardware) are also useful, but they are pretty thin. (link)
commercial small curved scraper set
