Have a question? Ask Woody!
Stupid pen turning glue questions
wilbur
>Actually, I'm not turning a pen, but I would like to turn a small ornament that uses the brass tube/mandrel set up that you would use if you were turning a pen.
Anyway, this is the first time I'm going to try something like this. I was told that I should use CA glue to glue the brass tube into my blank. But, I shouldn't get the CA glue that's sold at the borgs -- rather, the CA glue available through Packard or CSA are of higher quality. Is this really true?
So, I'm looking through the catalogs, and I also learn today that there are different consistencies of CA glue -- thin, medium, and thick. Never knew that before. Which one would be best for this purpose?
I was also told about needing accelerant to help the CA glue set faster, and that's when I started getting a headache. Do I really need this accelerant stuff?
Finally, are there alternatives to CA glue that I could consider?
Re: Stupid pen turning glue questions
Barry Turner
>Medium viscosity CA works very well on gluing the tubes in pens. You may want to rough up the brass tube with sandpaper before gluing to ensure good adhesion. I don't use accelerator when gluing these tubes in. I think the result would be the CA glue setting up before you could slide the tube into the blank. I've heard others have used Gorilla glue for this purpose. I don't use Gorilla for this or any other purpose. I normally don't have a need for waterproof glue and the clean-up is just too difficult........of couse there's always rubber surgical gloves to keep the hands clean.
>I agree with Barry. We mostly use the Accelerator to speed up the gluing with CA but it glues pretty fast without it and as Barry says sometimes too fast. You can often buy the better grades of CA glue at stores that sell model trains and radio controlled planes If you want to try and buy some locally. Of course most woodturners do buy it from the places you mentioned.
Polyeurethane glues do work good for this but I agree with Barry. I don't like the mess and it's impossible to clean off your hands. I've had to throw away half of every bottle I've used because it goes bad and it's already overpriced.
Epoxy works really well for this application, either quick set or slow set. You can clean it up with Alcohol or Acetone and of course it's easy to buy just about anywhere. The downside is you have to mix it but that only takes a minute. I keep a pad of post it notes handy and a box of toothpickes or popsickle sticks to mix it with. That means I never have to dig up something out of the garbage to try and mix the stuff.
Almost any glue...
Peter Teubel
>...will work. In fact, I generally DON'T use CA glue for pen blanks (expensive and too brittle). I prefer polyurethane. Any Titebond will work just fine also. Just make sure you rough up the brass tube with some 80-grit or so sandpaper.
JohnKJordan in East TN
>I rarely use accelerant for CA on anything. It will set up by itself with a dab of patience. In fact, I read once (don't know if it's fact) that the the CA bond can be compromized somewhat by using accelerant.
On thing - CA seems to set up very quickly with some woods (some exotics) especially if there is any heat. Since it's a disaster to have it set up while inserting the brass tube, I use a tip I read somewhere - put the blanks in the freezer for a while before gluing.
Small amount of expoxy tip:
Stuart Johnson
>A piece of duct tape stuck to your workbench works very well for a mixing pallet.
eaglesc
>If you only need a little any kind that says "gel type" will work and they sell it at the Borgs.
I have even seen small amounts of accelerant sold also. They might be a regional promotional item.
I've been turning pens for 3 years and use Ca for all my solid pens.
Too much waste with Epoxy and poly glues are too messy.
Denis Lalonde
>Polyurethane glues work good, if you find that your glue is getting too thick , stick it in a cup of hot water for a few minutes and it will pour out just like a new bottle....I happen to use a baby bottle warmer for about 30 seconds whenever my polyurethane glue thicjens up...
Denis
Ron in Drums PA
>I've tried every glue out there for pens along with all their variations.
For me, Medium CA works the best.
So is it true...
wilbur
>Thanks for all the responses!
So is it true that CA glue at the borg is not as good as the CA glue that Packard or CSA sells?
Re: So is it true...
eaglesc
>It is not a question of being as good or not, it is the viscosity,
For glueing in tubes there is usually too much of a gap to fill with thin viscisities.
Another consideration is to look at the CPS's of the glue you are using.
I try not to get too technical.I usually have thin, medium and thick on hand at all times.
I have found that different Mfgrs have different standards for what they think thin med and thick should be,
One companies thisk is similar to another companies medium.
The CPS's are the only standard you can use to compare different brands.
The main thing is to get good good adhesion with the items you are gluing.
