Tormek Turning Jigs
Tormek Turning Jigs
Tormek Turning Jigs
David - Indianapolis
>Having recently acquired a lathe and a number of lathe tools (gouges, parting tools, skew chisels, etc.) I am curious about the jigs that are available for the Tormek system. Would you recommend buying the turning kit ($240) that contains the universal gouge jig, multi jig, tool rest with TORLOCK, etc., or just one or two of the attachments,i.e., the SVS50 and SVS185 ($120). It is hard to compare because the kit does not provide part numbers for its components which would allow met to compare with parts available individually. As I have a Tormek, I would rather purchase attachments for this system rather than buying something new. My intent is to turn smaller items while learning, take a class or two, and see where my interests take me.
Thanks,
David
Re: Tormek Turning Jigs
Dennis Yoder
>Hi David, welsome to the vortex. I would suggest going up to Rockler and/or Woodcraft north of Indy and check out what they have hands on. You also want to join the local turning club, they have some fantastic turners and instructors. The ones I know are very giving with their knowledge. Dennis Y
Cyril Griesbach
>David, I don't own a Tormek so owners may over ride my thoughts but I think you could get by with just the Gouge Jig. The skew and parting tools could be sharpened on the platform. As you get more involved with turning you should be able to better understand what will meet you needs.
Learning to sharpen our tools is a skill that goes hand in hand with learning the turning skills. No one way is better than another...just different. Your very best move would be to seek out the nearest turning club in your area and when you do you'll find lots of help. Of course, there is lots of help right here as well.
Welcome to the Vortex.
Steven Antonucci
As a Tormek owner and a turner...
steve antonucci
>I highly recommend the gouge tool, the "skew" tool if you radius your skew, and the "platform" for any scrapers. If you don't radius your skews (or don't know what that means...), you can pass on the skew tool and use the platform.
Another thing you might be able to get away with for a skew is to use the "plane iron jig" and manually configure it. I did before I got the skew jig, but no radius...
Steven
Slow Wet Jet
Mike Jones, Redding, CA
>I shopped victoriously today and have a Jet wet/slow speed grinder coming (eBay $202) As I already have a Wolverine Vari Grind, my intention is to adapt it rather than buy the jet jig. Has anyone done this..sucessfully?
Mike Schwing from Md.
>As a Tormek user, turner, and flat woodworker, the ONLY Tormek jig I use is the one for flat plane blades. I dislike all of their gouge jigs, and instead have made my own when needed. I use the Ellsworth jig for nearly all of my turning tools, I just change the projection as needed.
I will say that the new screw driven truing tool is a dream come true, er.. no pun intended.
JohnKJordan in East TN
>David,
I had the same delemma and ended up buying the whole set, but for just turning that's certainly not needed. The jigs I use the most (can't remember the codes) are those for the universal jig for gouges and the multi-jig for skew chisels. The flat toolrest platform is great for scrapers - it came with two but I like the one covered with pastic better. I also use the plane iron jig for things like parting tools and bedan, but the flat toolrest can work as well. I use the small profiled honing wheel add-on for honing gouges. I made myself a little measuring block for the gouges. The other required accessory is a fat blue sharpie pen.
When I bought my Tormek some years ago I bought an extra grinding wheel and extra honing comppound, but I haven't needed either yet. The wheel lasts a long time if used carefully.
I will say the Tormak is the one thing (besides a good lathe) that makes my turning more enjoyable. Once the tools are initially ground to shape, putting a fresh razor edge on them literally takes only a few minutes and removes only a minute amount of metal. I have turning friends who have ground their favorite tools down to nubs, but by comparison, mine will outlast my grandchildren. The concave grind allows many honings with a fine diamond stone between sharpenings.
Adapting the Wolverine
David Propst
>Hi Mike,
Look under the "How To" section at www.turningwood.com and you will find instructions on adapting the Wolverine to the Tormek.
I have both, I use the Wolverine on a grinder to shape a new gouge and then the Tormek from then on. The Tormek gouge jig is very nice.
David
Pascal Oudet
>I almost only use the gouge attachment. (SVD185 I believe). for skew, bedan and scraper, I use my dry grinder, there is nothing dificult in sharpening them freehand, while it's more difficult to get a perfect shape on gouges.
Pascal
Fog Tanner
>I bought the Tormek orignally to sharpen planer and jointer blades, buying one of the package deals. Then I got a wood lathe and bought another package deal for woodturners. I think the only jig I don't have is for sharpening axes.
After all that, the jigs I use most are the SVS-185, SVS-50, and one which may be the SVS-32. The one which may be the SVS-32 was dropped by Tormek, but was still carried by SharpTools when I bought my turning jigs. I use it for sharpening roughing gouges. I also have a setup for using my Ellsworth jig on my Tormek, so that gives me four jigs for turning. The SVS-50 and SVS-185 are the ones I use the most these days. I turn everything from pens to 23" bowls and a number of shapes inbetween, so it doesn't take a lot of jigs for all the tools. These days I use a dry grinder with no jig for sharpening the scrapers, so I don't count those in the ones I need jigs for - even though I do have the Tormek jig for scrapers...
