Any tips on moving a 3520
Ron in Drums PA
>Any tips or links to tips on moving a 3520 from a garage to a basement shop?
Ron in Drums PA
Re: Any tips on moving a 3520
Bill Hale / The Wood Spinner
>Hire 4 BIG DUMB guys and slide it on planks.
Bill in CG, AZ.
Chuck Engstrom
>I have moved mine a couple of times. With a small rolling crane I borrow from a friend, I can do it by myself (see photo). Here's what you're dealing with:
Headstock: about 150 lbs with motor (itself 50 lbs), which does come off fairly easily. One of these days I'll install a disconnect plug set in the line from the controller to the motor so it can be easily detached for moving. In the meantime, I have to open the little black box on top of the motor and detach the leads. UNPLUG FROM POWER BEFORE YOU DO THIS.
Tailstock: 35 lbs, not much problem. Likewise banjo, about 20 lbs.
Bed: About 220 lbs. It can be carried up or down stairs on a hand truck without much trouble, or across flat area on a rolling table (as in photo). If you carry it vertically on a hand truck, don't forget to lash it in place.
Legs: about 75 lbs each. They will stand quietly on their feet unless you've installed adjustable feet with free-swiveling pads, in which case they will fall right over BOOM! (DAMHIKT).
You'll need an 8mm hex-head driver on a rachet wrench with extension to drive hex-socket bolts that attach legs to bed and motor to headstock. 5/16" would also be OK, it's only 0.0025 smaller. It's worth buying the driver if you don't have one; working with just a standard Allen wrench will get the job done but is kind of a pain.
I've heard that they arrive with legs attached to bed, which is fine if you've got enough folks to deal with 375 lbs in an awkward shape. Removing the legs is only four bolts and makes life a lot simpler, I think, and really doesn't take much time at all.
Good luck with it. I know you'll enjoy it. The one thing that takes a little getting used to is having to move that 20 lb banjo around -- you'll know you're not working with a mini anymore.
Best--
Chuck Engstrom
Dennis Yoder
>Is the basement directly down from the garage? If the framing is exposed then you can disassemble upstairs and use a block and tackle to slow the fall. Oh ya lots of help;) Dennis Y
Andy DiPietro
>Hey Buddy,
Congrats on the new lathe. When I put my 3520B in the basement I had two other big guys to help. The legs were still in the box. We took everything off the bed. We used a large hand truck on the bed and brought it down the basement. The other items we hand carried down the steps. We assembled the legs to the bed on its side then the three of us tip the unit upright.
The lathe was too low for my height(6'-3 1/2") so I made 6" high maple blocks. To lift the unit without help I used a 2ton bottle jack and lifted one end at a time. I later added the ballast box and 300lbs of sand.
Did you get a remote switch or are going to make one.
Have fun!
Andy DiPietro
Recent discusstion *LINK*
Jerry Hall
AAW re moving 3520
Good Thread Jerry, thanks
Ron in Drums PA
Ron in Drums PA
>Remote?
Never thought of that.
Ron in Drums PA
>Garage is in the front, Bilko doors to the basement in the back.
I'm going to need to rustle up some guys
Good Info
Ron in Drums PA
Bob Macgregor
>The rolling crane/engine hoist idea sounds almost ideal...except for getting it down to the basement! How much does one of those weigh? Do they come apart? Are they really as awkward a shape to take down stairs as they look?
Doug Thompson near Cleveland
>First of all ask a friend or two to help, I did it myself. The headstock on a dolly worked just fine it's the bed that's rough to move. I slid mine down the stairs on planks with a very long strap attached, it's a good thing some extra wood was placed at the bottom to stop it. The bed didn't crash down the steps but once it went over the edge I could only slow the decent but couldn't stop it. I did move a 8 inch jointer bed the same way with no problems.
The powermatic is the best value on the market... you did good.
Have fun, be safe and the yellow does grow on you in time.
Eddie Pacheco, San Jose, Ca.
>I also had to move one of these and chose to leave the legs on so that I could steer the bed leg assembly without being stooped. A friend and I got the bed assm., legs up, on a piano dolly and moved up a steep driveway to my garage.
Like the others suggest, put the bed on a plank or 2 x 8 and with straps or rope have you and another guy let it slide down using straps or ropes to slow down the descent.
It doesn't seem like the motor and spindle weighs 150#, but it is heavy.
Moving this was one of those times when I wondered if stamp collecting would have been a better hobby.
Good Luck.
Stuart Johnson
>You might contact the freight company making the delivery and ask what they would charge to deliver it to your basement. My second thought would be to check in the yellow pages for a company that moves machinery.
Every time I read on of these threads I have visions a bed flipping end over end taking out stairs and rail on the way to hitting just right to crack. Even worse is a major injury to you or one of your friends. I guess I'm just a wimp but sometimes in my mind it makes sense to pay the pros.
eliot d
>When I received mine, I did hire four big guys to move it from the driveway down to my shop. One guy just stood there watching the other three trying to lift it. I finally told them that it comes apart. They were able to move the headstock, the tail stock, and the bed attached to the legs, one section at a time, without too much difficulty. But it cost about $150.
Dick Hines
>Ron, just get to the basements steps and give a big push.
JohnKJordan in East TN
>You might search the archives - I remember a thread on this subject a few years ago with discussion of various options. Seems like someone documented the whole thing.
I'm sure it's quite a bit heavier than the Jet 1642, but I moved that myself by taking it apart in the crate and carrying the pieces with the help of a dolly.
Ron in Drums PA
>That's how my wife got the 1236 into the basement.
She told me it was pretty noisy on the way down.
Re: Move it to my place...
>I'll find a way to get it to the basement!
Seriously though - one piece at a time.
I have a big heavy duty Angelus dolly that I picked up at Costco a while back. It has moved a number of tools from my old basement to my old garage and my new garage to my new basement. But I had daylight basements in both cases.
The dolly is heavy duty and convertible from upright to horizontal. I could rope the tool pieces to the dolly and trundle them around my houses. It would work in the upright position if you had to go down stairs. If you don't want to buy a heavy duty dolly (or can't find one), try renting a refrigerator dolly. Either way, it would be at least a two person job.
Bruce Lane
>My thoughts exactly, 4 guys with big jackets and small hats.
The Egyptian Method......
>Your wife used the American Method. Just throw it down the steps.
The Egyptian Method would be to fill the stairway with sand. Put the lathe on top of the sand. Shovel out the sand.
There was a post here a few weeks ago about one falling over and landing on the lug for that crazy safety cage. It protected the control box. Now we know what that is for.
Stay above it. Not fun to watch your baby fly down the steps, but much better than trying to out run it.
Mark Paulley
>Ron,
Go rent a good appliance dolly. It makes going up or down stairs a breeze. Think about it . These dollies handle big refrigerators. While not weighing as much as your lathe regrigerators are big and cumbersome.
Mark
Don't Eat Prunes!!
Jorge Castaneda~Downeast Maine
>Ron,
Without reading the other responses:
The obvious, brake it is as many pieces as you can, then many hands make light labor, I have not experience yet a case where pizza and beer don't do the trick.
Have fun!
Jorge
Thinking I should bite bullets myself...
Ron, here is a site that... *LINK*
Clem Wixted
>...has some informtion on moving a 3520. There are also a bunch of entries from the home page about all things Powermatic 3520.
Clem
The Mustard Monster Site
Be carefull about gravity.....
Pete in Holland, MI
>My shop is in the basement. A 10" contractors tablesaw, 14" bandsaw, 6" belt sander, drill press, 1642 Jet lathe, & shaper have all made their way down there in the past 10 years....most often in pieces. Nice place to work, especially in the winter. Sucks to haul numerous trash cans of green wood shavings out each time I rough turn bowls.
Am dreading the day that we decide/have to move to a new house, and all that equipment will have to go UP the stairs, against gravity. I will be older when that happens, which will make matters worse then too.
