Finish for rosewood or cocobolo?
wilbur
>I'm trying to turn some bottle stoppers with East Indian rosewood and cocobolo for the first time. I've never used either of these woods before. I'm kind of stuck as to what I should use as a finish. I have read that both woods have oils in them, so I don't know if that would make some finishes either more or less appropriate for these woods.
Any suggestions? I have Waterlox and the Liberon turners' polish/wax stick system on hand, but could easily be persuaded to go shopping.
Re: Finish for rosewood or cocobolo?
JohnKJordan in East TN
>wilber,
My favorite finish for small diameter things made from cocobolo is Mylands friction polish since it is quick to apply and I think the high gloss emphasizes the contrasting colors without compromizing the rich blacks. However, I asked the same question recently when I made my first bottle stopper, since using the shellac-based friction polish did not seem like a good idea on something which could come in contact with alcohol. One answer I got was to just polish and buff the stopper and apply a little wax. I tried this on Pink Flame and it looks great.
A demonstrator at our club once showed how to use CA glue for a gloss finish on bottle stoppers. They looked great and should withstand alcohol.
I'd be afraid of a lacquer or something that might get chipped or scratch easily. BTW, I would NOT use any oil on cocobolo - don't know if it always does this but I did two pieces some time ago and the one I finished with Watco oil is almost as black as ebony now while the other (friction polish) still has good color.
I hope some experieced bottle stopper turners will respond with their experiences.
>I use lacquer on most of my bottle stoppers with no problems. Ive turned rosewood, cocobolo and ebony and used lacquer with no problems. I put it on pretty thin and then buff lightly with the beal system.
I've also used Hut abrasive sticks with success as far as the finish and it holds up well on the ones that I kept. I don't know how well it holds up to customers.
Mike Stafford
Mike Stafford
>I have used wax, friction polish and multiple coats of thinned varnish with great success on many dense exotics. Make sure you sand these woods very finely as any little scratch can show up under a finish.
keith zimmerman, Normal, IL
>I use Hut Crystal Coat on my bottle stoppers. It goes on easy and looks good. I have recently started buffing them after a couple of days with tripoli and carnuba wax on my Beall wheels.
keithz
Allen Neighbors
>I use my Lacquer Wash on Cocobolo. Haven't tried any bottle stoppers, but HFs and bowls have kept their brilliant colors. The one HF I have left is just like the day it was made.
The wash is about/approximately/somewherearound 35%Lacquer and 65%Thinner. Spun dry with tee shirt.
What I wound up doing
wilbur
>Thanks for all the replies. I wound up sanding the stopper I made out of rosewood up to 400 and using a Liberon wax stick, mainly because that's what I had on hand. It seemed to work well.
