Faceplate and thread problems
Scott Walton
>Hello all,
I'd like to know any ideas to a problem I have. I need to make some larger platters on my old Craftsman's lathe. My problem is, the out bound side of the lathe is a 3/4" 16... yes, somewhat standard I know but it is a left hand thread! I have seen the LH threads for 1"-8 but not 3/4"-16.
If anyone knows of an attachment that is a 3/4"-16 (left hand thread)female, to a 1"-8 right hand male adapter so that I could use my chuck...!
I have tried the Sears part and service centers but they no longer have these parts of even 3/4"16 LH face plates for that matter!
Any ideas would be appreciated!
Re: Faceplate and thread problems
Denis Putland
Denis Putland
>Hi
If you do a search such as "left hand 3/4 thread" you will come up with sites that sell that type of threaded nuts. you then can make your own face plates.
For a more accurate face plate have a friend who is a machinist make you one.
Denis
Using a chuck on the outboard side...
Clem Wixted
>...might require that you have a way to secure the chuck to the outboard spindle/adapter, if it's a right hand thread. Some chucks have a screw or screws that secure the chuck to the spindle so it doesn't spin off when you turn.
Clem
>Scott if you find a right hand faceplate check the threads. They often made their faceplates with both threads in them. It's easy to tell. When you look inside it looks like an X pattern instead of the usual thread appearane.
Bob Macgregor
>I got lucky and my cheap monotube lathe came with an "IN/RH" and an "OUT/LH" faceplate.
Good luck finding a fix or fixture for yours.
Re: Scott, be sure and post....
Allen Neighbors
>how you solved the problem. I would like to find something with 3/4x16 LH threads, also. :)
Oneway...
Peter Teubel
>Contact Oneway. They custom make adapters for almost any lathe/situation.
