Re: Neatsfoot oil
JohnKJordan in East TN
>Neatsfoot oil is non-drying (sources, The Neatsfoot Oil Refineries Corp., The Practice of Lubrication: An Engineering Treatsie...), hence it's use in treating leather. In the past it was also widely used to lubricate things like delicate machinery and watches because of it's clinging properties. Of course, it may react differently when soaked into wood - I've never read anything concerning it's use with wood.
Note that there is neatsfoot oil and there is neatsfoot oil. The old-fashioned "pure" neatsfoot oil was made from the feet of cattle; today it is apparently common to market a mixture of mineral oil and processed pig lard as neatsfoot oil. This is probably the reason I've read comments from oldtimey horsemen complaining that most neatsfoot oil today is worthless and is nothing like the "real" stuff in smell or consistency or function. The "new" neatsfoot oil may work differently on wood than the old.
BTW, I found this: May cause gastrointestinal irritation, nausea, diarrhea. May irritate eyes and skin. May cause difficulty in breathing if mist of spray is inhaled.
Both of the two containers of neatsfoot oil I have on hand are thicker and much darker than something like Watco oil, perhaps penetrating less and adding color. If you like the color or darkness it may add to your wood, perhaps you could get the same result with a spot of dye or stain mixed into a traditional woodworking oil with known properties. I've even bought some cans of walnut- and cherry-colored Watco oil I've used on occasion with good results. I'd trust that more on a nice turning.
