Had some fun this holiday weekend
Julie
>Turned 9 bowls this weekend, working on learning to use the bowl gouge without the ole catches. I had on very loud one and then managed to turn the rest without a to much stress. I turned about 75 to 90% with the gouge and then finished with the round nose scrapper. My biggest problem now is the sharp transition from bottom to side, on round bowl blanks, that sharp corner gets me quite often.
Re: Had some fun this holiday weekend
Carole Valentine
>Julie, I will suggest once again that you start with turning a shallow bowl that is a smooth, gentle curve from the rim to center of bottom - inside AND outside. On those steep sided, flat bottom ones it is almost impossible to make the smooth transition with a gouge. It looks like you are trying to use every bit of wood in your blank with the straight sided form. Unless you have a coring system, a good third of the outside of your round bowl blank should end up on the floor as shavings if you are going to end up with a good form. DOn't worry, it grows on trees. ;))
Even on a shallow, gently sloping bowl, there is a trick to making the transition. I could show you but I can describe it in words. Wally Dickerman probably can if he reads this.
>Sound like your having fun. This shape bowl is much harder to turn than a more open rounded bowl. The reason is the somewhat abrupt transition from the sides to the bottom. This requires a change in the gouge position. Sometimes you can rotate the flute up to go through this transition point.
My suggestion to start off is to make bowls that have a long gentle curve from the lip to the center. Take a short piece of chain like a necklace and hold the ends in your hand. Now move your hands apart until you get the shape you want. You can create a lot of different shapes of bowls but there won't be any abrupt transition points.
There's nothing wrong with the shape you've chosen. As your skills improve you can make any shape you want.
Carole Valentine
>Sorry if I sounded a little brusque in my first post. I just spent 3 days answering that hated question "But what do you do with it?" By this evening I was ready to tell them what I wished they would do with a couple of my hollow forms! LOL
You are having fun and that is what turning is, or should, be about. Every time you are out there having fun, you are also learning something.
bowls - PICs
Julie
>can someone post a couple of pics of the more rounded looking bowls that carol and john are speaking of?
thanks
beaded bowl
>Julie This is the closest one to your shape that I could find quickly. Notice the sides aren't quite as steep and it rounds smoothly into the bottom.
Re: beaded bowl
>Here is the bottom to help show the curve. I added beads and some texture to the bottom.
Bill Hale / The Wood Spinner
>Julie
As others have said I too preferr a longer inside curve. I just think it looks better.
This may sound a little contrary to what others will say but it works.
Move your rest in as close to the inside bottom corner as you can. Now present your bowl gouge with the flute looking left not quite vertical and the tool handle slightly down, 10 deg. or so. Now very gently present the tool to the wood and PULL OUT through the radius. As you pull rotate the handle away from you toward the edge of the bowl. I do this at high lathe speed.
DO NOT continue to pull out to the bowl edge or you will likley blow the edge of the piece.
Remember tool roled far left, high speed and be very gentle.
Good turning and be safe
Bill in CG, AZ.
Re: bowls - PICs
Troy German
>Julie,
This is a bowl I posted here last year. I think it's somewhat along those lines. The idea isn't that you're wasting the wood or not using the whole blank, but what is the best shape for each blank. Or more importantly, what do you WANT to do. When I show friends how to use the lathe I don't worry about shape at all. It's just fun for them to put tool to wood and watch the wood change shape as they go, and that's a good way to start. But eventually, it's fun to plan shapes ahead of time and use your skill to create what you pre-envision. This is getting kind of long winded, but I want to say it's fun to see your pictures, and I look forward to watching your skills develop.
Thanks for posting.
Troy
