Turning Light colored Wood
Julie
>UGH !!!
I tried to turn some pear today and it looks like Ucko..
it has black stains all over it. How do you go about turning it without having all those stains on it ??
thanks
Re: Turning Light colored Wood
Ruth Harding
>Julie,
they are supposed to be there.
Wait until you turn some heavily spalted wood....it's much sought after.
Keep spinning.
Allen Neighbors
>The stains are beautiful... leave 'em. My opinion is worth nothing, but it's mine, all mine.... :)
Keith Inscho E. Tenn.
>If the stains are in the wood when you start then leave em. Sometimes if you are turning wet/green wood, metals from the tools can stain the wood. Rubbing a little lemon juice on the wood or black fingers will make the stains disappear!
Try Dye
Bruce Forrest
Fog Tanner
>Worth is a relative term. An object by itself has no value, it only takes on value when it is of use to someone. And then that value is varied. The same can be said of an idea or opinion. By itself, unacted upon it is of use only to the originator. Its expression lays it bare before all, its worth is another story.
To conceive an idea or opinion is an exercise in time, that period required to perceive the situation and arrive at a conviction in thought. Whatever the duration, that is a use of very limited resource. We only have a limited amount of it at our disposal, at least on this rock. Time is a personal resource, one which we cannot save until a later period but must be used now or lost. What is its worth? In youth, where the road is long before you and no end in sight - time is abundant and value is low. But, as the supply grows low the value increases. How many would sell their last hour for five dollars, yet they gave their first away for free....
So your opinion, while it is still your possesion, is still valued by others. A kind word you thought enough to give away part of your life in sharing - those are what you cannot put a price on and far from worthless.....
Take care,
Fog
Re: Thanks for the depth, Fog. :)
Allen Neighbors
>That is deep... thanks for your time. :)
