Vicmarc 300
Vicmarc 300
Vicmarc 300
gtw
>Finally got the lathe wired up today after moving, however when I turned on the VFD 2 little square red lights lit up and when I shut down the code LU came up.
Is there anyone out there in Vicmarc land that knows what this means?
Lathe runs both forward and reverse but the VFD makes a funny noise when I turn it off, don't want to run it in case of problems.
Any ideas gratefully received, Trevor
Re: Vicmarc 300
Re: Vicmarc 300
Phil in NJ
>what brand of VFD and model # is it?
Re: Vicmarc 300
Re: Vicmarc 300
gtw
>Phil,
It's a Fuji Model # FVR-E11s-7/7JE
Single phase 200 volt input, however I am reading 238 volts at the receptical, I have a 20amp breaker in the load center and a 30 amp breaker in the main panel in the house. Wired with #10 Tec and then #12 to the receptical.
The lathe has been dormant since January, perhaps just didn't notice the red lights before but this morning I noticed the green run light is on also. The red lights are the first and second on the key pad.
Thank you, Trevor
