Photo Question
Photo Question
Photo Question
Bill Crommett
>What does it take to convert some older 35 mm color slides to a jpg format or another format for the purpose of e-mailing. ? I would like to get these preserved before they lose all the color.
Re: Photo Question
Re: Photo Question
JohnKJordan in East TN
>Bill,
The local photo store will scan negatives and slides and put digital files on a CD. I suspect you have a store like that nearby.
If you want to do this yourself, for best quality use a dedicated 35mm film/slide scanner. This will accept strips of film or individual slides. I've bought several over the years and I've been less than impressed with some. The one I've been using for a few years is a Nikon and I think it was somewhere between $1000-$1500. I haven't researched this lately so there may be better deals available today.
Note that slide scans are normally at quite high resolution and may need to be reduced in size or more highly compressed to make them small enough to email.
Re: Photo Question
Re: Photo Question
>There are 3 ways. Shoot them your self with a digital camera. This is similar to doing a copy slide. This is the worst way but in a pinch it gets you an image you can send.
Scan them yourself with a slide scanner. Some are better than others and it depends on your computer skills how well some programs work.
Send them in. This is the best quality but very expensive.
Re: Photo Question
thanks, Clay
garyg in md
>I've been meaning to get something like this, and this looks like a good one -- thanks a lot! ...Gary
Re: Photo Question
John,John and clay
Bill Crommett
>Thank you, fellows. You have given me some good alternatives.
B
Re: Photo Question
Re: Photo Question
Ron in Drums PA
>I picked up the same scanner for my girls. It did a great job on slides and some old B&W images.
Re: Photo Question
I'm a bit surprised
Bill Howatt
>I'm surprised at the "use a scanner" advice and how great it is. Now, I'm not speaking from personal experience but I've done a bit of reading on this since I have a lot of slides that should be copied. I would say that the common thread is how much of a boring, time-sink it is to copy slides with a scanner.
I have a friend who has an expensive Nikon slide scanner and he says it is a slow process with it as well.
Obviously, it depends on the nature of the slides but if a lot of them are vacation, family-event shots then real high quality is not likely to be an issue.
One method, that I plan on trying as well as using my Epson scanner, is to make a board with 4-dowels placed on it. There are 2 dowels on each side of the board at a width to hold a 35mm slide. The 2 dowels form a groove to drop the slide in. Obviously, keen woodworkers could make any sort of simple holding device.
The tricky part is getting good, uniform, indirect lighting to evenly illuminate the slide.
There is a hole in the board at the appropriate distance from the slide to use the camera's tripod-mount screw-hole so the slide and camera are fixed with respect to each other. The camera is set to macro and off you go after a bit of experimenting to tune the process.
Bill
Re: Photo Question
Re: I have been quite satisfied with......
Jamie Donaldson
>... the scans from my old Epson 3200 flatbed which will scan film sizes up to 4"x5"(2), and the slide holder allows scans of 4 35mm slides at one time. I certainly don't see any need for "average Joe user" to purchase a dedicated scanner when such good results can be achieved with more versatile and inexpensive equipment.
Re: Photo Question
Re: Photo Question
Ken Grunke from SW WI
>I have an old Umax SCSI flatbed scanner hooked up to a Mac G3, with a transperancy lid that will do 6 x 9". At 600 dpi setting, it produces a nice enough image from a 35 mm slide for the web, but not that great for printing.
Re: Photo Question
Re: Photo Question
Peter Hyde
>Well I spent quite a few hours scanning slides from a European trip I did in 1967. They were really deteriorating and I didn't want to lose them. Most were badly faded and some had mold spots on them as well as lots of dirt and dust.I used an Epson Perfection 1660 scanner with a slide holder and Vuescan scanning software. In Vuescan I set up colour correction, white balance, and other image restoration features and ended up with scans as good as or better than the original quality. They were also good enough for 10 x 8 prints. Time consuming? Yes I thing I spent about 8 hours doing 200 slides but it was certainly worth it.
Re: Photo Question
Re: Photo Question
Gary in Zirconia,NC
>I just bought a Canon 8800F slide scanner and started using it yesterday. I am averaging a little less than 1 slide a minute. Results are excellent. This is a new model with no waiting for the bulb to warm up.
Re: Photo Question
Re: I'm a bit surprised
GaryG in MD
>Bill,
Yes, you're right. It's a very labor intensive process. I'm not sure how your camera jig makes the process much less time consuming, however. The scanner comes with a holder for 6 slides at once and the results go straight into your computer file. The scanner may take a little longer for one pass than pushing your shutter release, but doing 6 at once is a considerable advantage. After you have taken the photos with your camera, then you still have to take the time to get them onto your computer. Bottom line -- either way, it's not something you're going to want to do except for your "special" keepers.
...Gary
