Re: digital calipers
JohnKJordan in East TN
>John,
I've avoided the fractional digital calipers for that reason. In my mind I put those in the same catagory with the measuring tapes with the 1/8" fractions printed all down the tape - seems more annoying than useful. I prefer to work with decimal points, converting most fractions in my head if needed and with a table for the others on a handy plastic ruler.
I have four sets and one bad experience. One cheap caliper runs the battery down quickly. Probably no coincidence that it's the only one with no 'off' switch - it turns itself off after a period of inactivity. I do notice a distince difference in the smoothness of operation and in repeatability in the more expensive calipers.
Even though some people see no use for digital calipers around the lathe, I use them quite a bit, for example to measure threads and drill bits needed for those threads. Another real valuable use for precision digital calipers is for taking relative measurements from a photo or undimensioned diagram and scaling to real dimensions.
For relative dimensions and sizing on the lathe I use the ultra-cheap stamped steel calipers and round off the tips.
