nut allergies and walnut oil
BQ in VT
>Is walnut oil, as a finish for food surfaces safe when dry for people with nut allergies? Also, can the wood itself set off allerigic reactions when used for utensils? For example, someone who is allergic to walnuts, are they going to have a reaction to walnut iol or the walnut bowl they are eating out of? Thanks in advance.
Re: nut allergies and walnut oil
Carol - now in NC Nebraska
>Hard to say. Everyone is different. But why take the chance?
russ Fairfield
>The allergy is to the proteins in the oil, and that depends on whether the oil was from pressing or distillation. Pressed oil contains proteins, distilled oil doesn't. Good luck trying to explain that difference to someone who has, or knows someone who has, an allergy to Walnuts.
Re: TEST nut allergies and walnut oil
Bill Hale / The Wood Spinner
>An easy way to tell is to put a drop of oil on a bandaid and tape it to the inside of the forearm. In an hour or so remove the tape and see if there is any reaction.
You may find touch and ingestion to be very different.
Good turning and be safe
Bill in CG, AZ.
Check with an allergist.
Troy German
>It's not that I don't trust the advice you'll get here. It's just my belief that health concerns should be addressed by health experts.
Troy
>While I generally agree with all that was said here there are a number of questions you need to ask yourself. Mike Mahoney sells Walnut Oil that is processed to avoid the allergy. OTOH there is a story floating around about David Ellsworth turning a piece of walnut and it nearly killed him. His wife took him tot he hospital in time. So, Why take the chance? If you thought you had a nut allergy why would you turn walnut or use walnut oil? Or give such a piece to someone who might. A person with a nut allergy could recognise the wood but might not be able to distinguish the oil.
It was Russ (I think)who pointed out that if a bowl smells like finish (lacquer, varnish, whatever) many people will not buy the bowl for food. That was an Eye opener for me. Why finish a bowl that has a chance of turning off your customer. Use something that smells like food. Walnut oil smells good unless you have a nut allergy. How about sunflower or safflower oil?
And Checking with a health professional is a good Idea, unless you get one that got an F in nut allergies.
Curt Fuller
>I don't know much about nut allergies, but the one I've heard of most is an allergy to peanuts. Peanuts are a legume, not really a nut. So I wonder if those that are allergic to peanuts would have any allergy at all to true nuts such as walnuts, pecans, etc.
FWIW...
Peter Teubel
>A friend of mine is DEATHLY allergic walnuts (and most other nuts). However, he turns walnut wood and uses walnut bowls for holding all sorts of food with no issues whatsoever.
robo hippy
>I asked Mike about his oil. It is pressed from the husks and leaves, and not the nut meats which have the proteins. When distilled, the heat will break down the proteins that can cause allergies. This same heating will also break down whatever it is that lets the oil polymerize, cross link, or whatever it does to let it cure and harden.
robo hippy
Mike Stafford
Mike Stafford
>This will not provide a definitive answer to your question but should explain why your concern should lead you not to use the walnut oil as a finish. The current regulations require food manufacturers to specifically label foods that contain protein from any of the eight major categories of allergens. They are peanuts, treenuts (which includes walnuts, almonds, cashews, brazil nuts, hazel nuts, pecans, etc. etc.), milk, soy, eggs, wheat, fish and crustacean shellfish.
Just as Russ said the key word here is containing proteins from those categories of foods. Some people have sensitivities so severe to these allergens that the mere exposure to anything even derived from them causes a problem. Case in point, it used to be a common practice to use a finely ground walnut shell powder as an anti-static agent in the production of packaging films. The concern over allergen sensitivity has eliminated that practice. Just recently the law changed requiring "Plain English" labeling so that when, for example, casein, whey or some other derivative of an allergen is used as an ingredient the label must clearly state that the food contains milk. You may have noticed that on some food labels there are statements such as "Produced in a facility where peanuts and treenuts are also used." Here is a link to an article explaining FDA regulations. http://www.cfsan.fda.gov/~dms/ffalrgn.html
I wish I had a definitive answer but with food allergies I don't think you can ever be sure how little or how much exposure will trigger a reaction. Just like Carol said, "Why take the chance?"
>Barry nailed it I think. Any time you have to try and explain to a customer that the bowl is food safe you've already lost the sale, whether you are correct or not. Most of my bowls are for show so I use lacquer. I have used Walnut oil in the past and will continue to use it for family and friends because I know what I have is food safe. If I start selling bowls to customers again I'll probably go with one of the Beeswax type finishes simply because you don't have to explain or argue that one with anyone.
No matter what you use........
Rick Davenport
>.....somebody is allergic to it.
I tell my customers up front that I use walnut oil and recommend it (or mineral oil) on my use and care card that I enclose with every bowl.
If someone is allergic to nut oils, then they shouldn't buy one of my bowls.
We all have allergies and we need to be responsible for them.
Personally, I'm allergic to hard work and Republicans.
I avoid both and stay happy and healthy!
Rick
Re: This is my Use and Care ...
Allen Neighbors
>sheet that I give with every bowl I sell... those that are for use of foodstuffs, that is.
I don't use any mineral oil anymore, the link will explain.
To keep your bowl like new:
After using the bowl for food items, do not let it stand for a long time. As soon as you�re finished eating, wash it with warm soapy water, rinse well, and towel dry.
To season your bowl after it has not been used for a while:
After you have used your bowl, sometimes after sitting for a period of time, some grains of the wood may raise a little, causing some rough areas to exist. If there are some rough spots, smooth them out with #0000 steel wool. Wipe it out. Wash it with warm soapy water, and towel dry. If it seems like it needs to be �sanded�, after washing, put in a spoon or two of salt, and be gentle: scour the inside with a paper towel, using the salt as grit to �purify� and clean the inside. Rinse, and wipe it dry.
Note: DO NOT use Mineral oil, or extra-virgin olive oil, or any type of vegetable oil. http://www.gi.alaska.edu/ScienceForum/ASF11/1121B.html (This explains that Wood is better than any plastic for food items) Quote: Research Scientists smeared wooden boards with about 10,000 cells of Salmonella, Listeria, and Escherichia coli, cultured bacteria. That's about 10 times the number of organisms that typically wash off a contaminated chicken carcass. Within three minutes, 99.9 percent of the bacteria were unrecoverable and presumed dead. By the next morning, the researchers couldn't recover any live bacteria from the wood. Next, the scientists upped the germ count, inoculating the boards with a million or more bacteria apiece. Then they had enough survivors to work with, but not for long. Within two hours, again 99.9 percent of the bacteria had vanished. The only thing they've found that does enhance bacteria growth is treating the wood with mineral oil.
