Re: Turning mesquite
Fog Tanner
>I live on the other side of Texas, in the eastern portion. I get Mesquite from all over Texas when I can (Have Trailer, Will Haul). I turn either green or dried, mostly dried these days as I still have some peices in the stack. There are several varaiations around the state, resulting in different colorations. Mainly from the soil variations. The Mesquite I have from Central Texas, will like be different in color than yours, but still mesquite.
It is a wonderful wood to turn green as it does not move very much. The first bowl I made was from green Mesquite and it is still round. For boxes and pens, I let it dry. I rough turn the boxes and set them aside for a few months. Pen blanks, I just cut into boards or sticks and set them aside like the boxes. There are a number of us in the Houston area (fairly large area) that turn bowls and everything else from Mesquite.
It is best to get to the dead mesquite pretty quick. It will usually pick up some livestock and the less grazing they can do the better off you are. If you do get there a little late, the "trails" (i.e. holes) can be filled with coffee and glue and will look like they belong there. When you run out of dead mesquite and start looking at the live stuff, since you don't have to haul it very far it is best to only take what you can turn quickly for the critter reason.
I once asked Raffan about cutting a piece of Mesquite crouch I had. It was at a workshop and took the log in my van. First thing he asked was if all Texans carried their wood around with them. The second remark was "why would you turn anything else, this is God's wood"... so according to Raffan's thoughts, you probably have a lifetime supply of turning stock ....
