?'s 4 Allen Neighbors & others - inertia sanders
Carol - now in NC Nebraska
>My roller blade wheels have the inner race of the bearing proud of the wheel itself. Did you have that and what is the work around?
Also the outer edge of the wheel is rough and gritty from wear. Anyway I can pretty that up?
How long did you cut the all-thread rod? How much length is buried in the handle?
How did you cut the flip flop pad? Band saw? Hole saw? Did you get a smooth edge? If so, how?
Did you glue the flip flop pad directly on the wheel or did you cut out a plywood circle to glue on the wheel (which might solve the proud bearing issue)?
What kind of glue do you recommend to glue material (either the sponge rubber flip flop pad or wood) to the wheel?
What kind of glue for the hook material to the flip flop pad?
Which grits do you keep on hand?
Do you cut out sandpaper disks from H&L sheet stock? If so, what do you use as a cutter? Hole saw? Some sort of punch? Any comments on the wavy disks? Worth the money?
I am thinking of using a long carriage bolt with a locking nut instead of just gluing it in the wheel. If I round off the square shoulder and use a plywood disk between the flip flop pad and the wheel, I can bury the proud bearing and the carriage bolt head. Thoughts?
Thanks, folks. Play time in the garage today!
Re: ?'s 4 Allen Neighbors & others - inertia sanders
>I have not made them from wheels, but I made some from other sanding disks. I took a scraps of hardwood and drilled a hole through them for the shaft of the sanding disk. On the ones where the shaft was at an angle, I counter bored them with a bit that created a flat spot, either a spade bit or a Forster bit. I used a "cap nut" to hold the disks in the stick. (Lowes had the Cap Nuts. (They look like a little Panama hat with little teeth inside that grip the shaft and hold them on. Used on Wagon Wheels on the shaft)
In some of mine I used sanding disks I bought at Loses that were about 5 or 6" in diameter and then cut them down with a sharp skew on the lathe. On others I used ready made disks. Some had PSA Sandpaper. If you make one for each grit, PSA might be cheaper and better since you don't have to change back and forth.
Sometimes I counterbored them for bearings that I stole off skate wheels and some of the them the shaft just ran in the wood with a little oil.
All of them worked, but I have switched to power sanding and don't use them anymore.
There is an article in the Articles section about cutting you own "disks" from H&L paper. Actually squares, cut with an old bandsaw blade. You can buy one yard long pieces of the Paper a meter wide from Industrial Abrasives and make pieces for about a nickle a piece, I think.
Re: Carol, Email sent.
Allen Neighbors
>Thanks, I got it.
As soon as the heaters arrive, I'll be good to go. I had planned to work on turning and sanders this weekend, but with temps in the teens and no heat in the garage, no way, Jose!
