Re: finishing Bowls etc
JohnKJordan in East TN
>Julie,
I might use a different finish depending on my mood and what the wood looks like. For example, I think wood with deep, dark, sharply contrasting figure sometimes looks better glossy since the sheen from a less glossy finish can make the blacks less black. On the other hand, some low contrast woods look better to me with a softer finish.
For small things, I usually get a glossy finish with a friction polish, applied either on the lathe or rubbed out by hand. Larger things are harder to friction polish, so I usually let multiple coats of oil dry over a week or so then buff whith the Beall buffing wheels.
For softer finishes, I might use sander sealer as a final finish and buff by hand with fine steel wool. This works with a oil finish as well. On e.red cedar I like to use beeswax since it doesn't soak into and darken the wood and it lets the cedar smell come through for a time.
I found out the hard way not to put oil on cocobolo since I had some oiled pieces turn almost black in a couple of years. This scared me away from oil for other hard exotic woods as well.
Some people I know routinely spray on lacquer and other clear finishes from a can, but I have not yet been happy with that on my turnings.
