Re: CA glue
GaryG in MD
>Jim,
Yes indeed, CA is very exothermic. The amount of heat energy that it gives off per unit weight is considerable. The amount of temperature rise that you feel depends on how quickly that heat is given off -- i.e., how quickly it cures. The cure rate depends on how much accelerator is present. It you put CA on a very dry object in a dry room, it is likely to just sit there and look at you, just as it does in the bottle. That's one reason we buy accelerator. (BTW, the accelerator is NOT safe on some plastics -- it will dissolve them. DAMHIK!) Water is one accelerator for CA -- perhaps someone in the know could tell us why we don't just spritz water instead of buying accelerator?
I might add that some fraction of turners throw the cap away and leave the top open. I personally don't.
If you get a small amount of CA on your dry fingers, you can glue yourself to anything you touch. You can use it as a Band Aide for a cut (you didn't hear it from me), and I use it all the time on fingernail splits. If you get CA on wet fingers, be prepared for a potentially serious burn.
I came close a few days ago when fixing a ripped stuffed animal -- I nearly stuck myself to a koala, and boy did I feel the heat. The reason? The koala was dry so I used perhaps a little too much CA on one side of the tear and accelerator on the other -- and then held the joint together with my fingers. Never again. I came very close to getting a burn because my finger also simultaneously got a bit stuck in the fur.
In short, CA is safe if it is handled with care and respect. CA can be very dangerous if you get careless with it. I expect that there is enough energy (Joules, ergs, BTUs, pick your units) in a 2-oz. bottle of CA to cause an explosion and fire if it were to all get wet at once. Take care. ...Gary
