Persimmon Box
Persimmon Box
Persimmon Box
Ray Binnicker
>This is my first post of a turning I've done. I was on a couple weeks ago seeking help with my lack of sharpening skills (we won't talk about that today). This is a persimmon box; 2 1/2 x 4" finished with friction polish. Critiques welcome (and kind words) (:-).
Ray Binnicker
Re: Persimmon Box
Re: Persimmon Box pic # 2
Ray Binnicker
Re: Persimmon Box
Ron McKinley
>Nice box Ray. I think this is the first time I've seen persimmon wood. My wife loves persimmons and planted a tree this past Spring but will be a long time before it's big enough for me to turn it! .....Ron
Re: Persimmon Box
Re: Persimmon Box
Mike Jones
>Looks like a real nice fitting lid and good grain matching. Hmmmm,I know where there are a couple of standing-dead persimmons....
My favorite tool for interior box bottoms/sides is the "Berger" tool.
Keep up the good work!
Re: Persimmon Box
Ray Binnicker
>Thanks Ron. Where are you located?
Ray
Re: Persimmon Box
Re: Persimmon Box
Cyril Griesbach
>Well done, Ray, but I think I could do without the tapered bottom.
Re: Persimmon Box
Re: Persimmon Box
Ray Binnicker
>Thanks Cyril
You're right. I did get a little carried away with that taper. I intended to have a slight taper, rookie me, had a catch, you know the rest of the story.
Ray
Re: Persimmon Box
Re: Persimmon Box
JohnKJordan in East TN
The standing-dead persimmons I have here are riddled with big holes from fat worms that start under the bark. I haven't tried turning those, but they may actually be quite interesting. (The woods here are loaded with persimmon trees, some quite large.)
I love turning persimmon, especially for things I want to be heavy. I have a friend who has no control over his fingers so I've turned special cups for pencil holders with thick, wide bases that won't tip over easily. Persimmon turns cleanly and finishes nicely. Some people say it's kind of bland but I like the look. All the trees I've cut have had tiny little jet black hearts, but they say occasionally you'll find one with significant black. (Ellis said if anyone gets persimmon with black, he wants some!) BTW, persimmon is in the ebony family.
However, persimmon warps like nothing else I've seen! I had 2x6 boards from the sawmill cup nearly an inch in the middle. Things turned across the grain will go way out of round unless they are dried carefully.
I like the box, especially the fit. I haven't been brave enough to post pictures of any of my boxes yet, especially my persimmon box which was a disaster.
Re: Persimmon Box
Mike Stafford
Re: Persimmon Box
Mike Stafford
>Ray, for a first box I think you did yourself and the wood proud. I would have opted for not having the tapered bottom but a catch changes our plans doesn't it? I particularly like the detail on the inside of the lid. Your next box will be better and so will the one after that. Keep up the good work.
I hollow with a variety of tools but my stand by is a Henry Taylor detail gouge with a shortened bevel for rough hollowing. After that it is definitely the Hunter Tool for finishing up. I may use a square scraper to clean up the corners on the top and bottom also. Square might be a misnomer as I usually create a slight roundover on the left corner so that the tool doesn't dig in there. I also relieve the end of the scraper so that it is 85 degrees or so rather than a straight 90 degree angle. That way it is not as likely to catch on its width.
Re: Persimmon Box
Re: Persimmon Box
Ray Binnicker
>Thanks John,
I think I may have gotten the fit a "little" to tight. It has a nice crisp "snap" when you close it. I thought about sneaking up on it little bit more but thought twice about it and left it as it is. It will wear in a bit I guess.
Ray
Re: Persimmon Box
Re: Persimmon Box
Ray Binnicker
>Thanks Mike,
My curent hollowing tools are the "Termite", round nose scraper, and square scraper. I have the Hunter, but am still gaining confidence with it.
Ray
Re: Persimmon Box
Ron McKinley
>Apple Valley, CA
Re: Persimmon Box
Re: Persimmon Box
keith zimmerman, Normal IL
>Nice first box Ray. I like the Persimmon. I've only turned it once and I really enjoyed the experience. I wish I could find more of it. The single piece I had had turned dark and really looked good once finished, in fact the wood was a deep forest green.
The only thing I would change on your design is the base. I find the taper distracting and it takes my eye away from the beauty of the wood.
Keep turning boxes. Each one will get better than the last and if it doesn't, then there is something to learn there too.
keithz
Re: Persimmon Box
Re: Persimmon Box
Gil Jones
>Ray, good looking little lidded box.
Gil
