Eastern Red Cedar
Eastern Red Cedar
Eastern Red Cedar
Barbara Gill, Remlik VA
>I just got a last minute commission for 4 bowls from Eastern Red Cedar from a special log. I have always found the wood to be very stable but have never turned it green to finish. Does anyone have experience with this?
Re: Eastern Red Cedar
tek-Brunswick, Ohio
>I never turned it green, but I won a bowl blank in a club raffle. The member that cut out the blank told me it needs to be dried very slowly or it will crack.
rthomas
>I think it depends on the number of knots other wise does not move very much. Hope this helps,
Thanks Tek and rthomas
>My experience with boards is that they can be dried out in the sun and still will remain flat. I guess I will rough out all 4 and then decide what to do.
Ray Binnicker
>Hey Barbara,
Have you ever turned E. Red Cedar before? If not, be aware the dust can be very irritating to some people.
Ray Binnicker
Re: Thanks Tek and rthomas
JohnKJordan in East TN
Same here, I sometimes take them off the sawmill and spread them out flat on a trailer in the sun an flip them 'bout once a day. In short order the MC is down enough on 4/4 to put them in the barn.
My experience with turning green cedar is only it seems to check easily with heat so I'd go easy on the sanding. Since it's so soft, I've had good luck with using cabinet scrapers instead of sandpaper.
>Thanks Ray. Yes, I wear a respirator.
>Thanks John; I will be careful.
Yes, if I am keeping the boards around I rack them up on the sunny side of the sawmill.
Good Point
tek-Brunswick, Ohio
>Sanding Eastern Red Cedar can be a challenge. It is soft so it scratches easily and it is very fine grained so it shows even small scratches. I had to sand my bowl down again after I put on the first coat of finish (Waterlox) because I found a bunch of scratches I didn't see earlier. Of course the glossier the finish the more the scratches show.
George Balock
George Balock
>Barbra,
Don't ask me how I know this, but you need to be careful sanding ERC, as the heat of sanding can crack the wood.
George
russ Fairfield
>Why not turn it to final thickness and rough sand while the wood is still wet. It will dry faster and not crack. The worst thing that can happen is it will warp and look like a piece of wood.
>Thanks Russ and George. I roughed out the 4 bowls today. Tomorrow I am going to start taking them to completion.
