200+ woodworking book reviews
Elm Bowl
Elm Bowl
Steven Antonucci
Elm Bowl
steve antonucci
>Here is a bowl that I turned from some siberian elm that Andy DiPietro and I spent a day in a field cutting on... left 10x what we took.
It's probably 14"x4", and an inch thick. I left the rim thick because I was going to inlay some abalone shell (I bought beads on ebay). I think it would look OK, but I think it would go better with walnut. Comments welcome.
Steve
Re: Elm Bowl
Re: Elm Bowl
Tim GC
>Leave it as it is.... clean lines, wonderful grain.
just my �0.02p
Re: Elm Bowl
Re: Elm Bowl
eaglesc
>The wood/grain is certainly breathtaking.
Have you considered leaving the rim wide for the inlay but turning down the outside to create a "flare" at the lip?
(the thick walls make it look heavy almost "clunky")
What do I know I have never turned a "bowl" larger than a coffee cup without a handle.
Please don't paint it.:>)
Re: Elm Bowl
Re: Elm Bowl
Cyril Griesbach
>That's a nice bowl, Steve, and a beautiful piece of wood. I've seen a bunch of Siberian Elm here but I'm not at all familiar with it. I can't say it's too thick but I think I'd have turned the rim down into the inside to give it a more delicate (for lack of a better word) look. Could you tell us more about the Elm?
Re: Elm Bowl
Steven Antonucci
Thanks all-
steve antonucci
>Thank you all for the comments- The bowl was left "heavy", with a slight undercut at the rim so that your thumb had a place to go when lifting. In retrospect, it's a two handed bowl anyway, since you'd need pretty strong hands and arms to carry it with just your thumb hooked.
I promise not to paint it.
Siberian elm turns pretty easily, with a slightly antiseptic smell- almost reminds me of bandaids! The tree that Andy and I worked on was almost 3 foot in diameter, and you can see how wide the growth rings are. The picture doesn't show it, but the sanding left the surface with a mild texture that follows that grain, moreso on the outside than inside (intentionally).
The tree was loaded with burls, and what wasn't burled, was at least birdseye or spalted. If you look below at Andy DiPietro's hollowforms, they come from the same log (and hours of trying to snap it with my 6' pry bar...)
Steve
Re: Elm Bowl
Re: Elm Bowl
Don Orr
>Very nice! I love the grain and mass of this bowl. Time to go get more of that wood ?
