New Sharpening Tool *LINK*
Ron McKinley
>I saw this in Portland at the AAW this past June and tried it but it was not available for sale in the U.S. A few days ago I e-mailed Sorby and heard right back that it's available now in the U.S. I called the company and discussed it with them and it comes complete for the woodturner. I should have it in about a week to 10 days.
Does anyone else have this system and if so what do you think about it? Once you get to the link click on "New Products", upper left side of the page and you'll see it. Thanks...Ron
http://www.robert-sorby.co.uk/
Sorby Pro-Edge Sharpening
Re: New Sharpening Tool *LINK*
How much $?
Mike Jones
This sounds very interesting...
keith zimmerman, Normal IL
>and I am interested. Can't wait to see your review of this new sharpening system.
Please post something about your learning curve once you get it.
keithz
>Ron I saw that listed in an issue of Woodturning last year. I've been lusting after one ever since. It's probably out of my budget but I like it.
Ron McKinley
>It's available from Klingspor for $499--cheaper than the Tormek if you get all the accessories for turning--and much faster.
The Pro Edge Plus comes with the following accessories:
Sliding Skew Jig - for skew chisels
Standard Gouge Jig - for gouges
Fingernail Profiler - for perfectly sharpened fingernail bowl or spindle gouges
Aluminum Oxide belts - 120 and 240 grit
Aluminum Zirconium belts - 60 grit
The link is: http://woodworkingshop.com
The stock number is: SZ00095 and shipping is $6.99, and it's not on their website or catalog yet. I'm really looking forward to a really quiet, neat and safe sharpening system. To order it you have to call their 800 number.
I'm really tired of all the dust/mess with a grinder and the inherent danger of exploding wheels which I experienced years ago, fortunately, without an injury. I used it at Portland and was really impressed........Ron
>I am interested in your review also. Looks great. A couple of questions.
Why would a belt be any cooler than a stone? The text says it a "cool running belt".
Does the belt run up or down? INTO the tool's edge or AWAY from the tool's edge?
Are the belts a standard size or do you have to buy them from Sorby?
>Good questions Barry. I know most knife makers use belts rather than grinders. I've used a belt to sharpen and to grind metal and believe me the metal gets hot. I think it gets just as hot as using my white wheels. I know my gray wheels heat the metal up faster and don't cut as fast. I'm guessing that a belt doesn't load up as much and therefore probably runs a little cooler than a grind stone but it will still heat a tool red hot if you leave it there very long.
Randy Privett
>I've been using a belt sander for years. Does a good job.
Randy
Phil Joines Krum, Tx
>Lee Valley has had a 1x42 belt sharpener for some time. I use the 15u belts for knives and carving tools. Gives a mirror finish.
Here's a link to the belts.
http://www.leevalley.com/wood/page.aspx?c=3&p=48040&cat=1,43072
Sander
Denis Putland from Saskatchewan
>I have been using a belt sander for a year now and total cost with home build jigs is less then $100.00. Sander is mounted so the belt runs away from the tool edge.
With acurate jigs your tool should only touch the belt for maximum of five secounds, perhaps ten if you are touching up the shape a bit.
The only time there is any heat build up is when you are reshaping.
Denis
Stuart Johnson
>I fail to see what this will do that a more inexpensive belt sander with a few jig won't do and a lot cheaper.
A belt is cooler but...
Brian Hahn in SW Wisconsin
>I agree that a belt runs cooler, probably because the grit stands proud on the surface and so more air is dragged along by the belt to help cool the edge. But that doesn't mean that the edge will stay cool.
Last week I was reshaping a scraper and the body of a scraper turned a light straw a full 1/2" back from the belt.
Herm DeVries made this sharpening station *LINK*
Clem Wixted
>It's about half way down the page and is based on a belt sander.
Herm DeVries Sharpening Station
Click on Tools and Tips
Clem Wixted
Steven Antonucci
Other reasons knife makers use belts
steve antonucci
>They don't need to fuss with retruing wheels.
They can change grits in seconds for different operations.
Belts are cheap.
You are right about the belt cutting fast and hot. I've used my belt sander upside down in a vise, and the metal shavings tend to get pulled in to the sander. Be careful, since I've seen little hot glowing embers in there if you are going to use a belt sander- you don't want to have a shop fire!
Speed=heat. Keep a small bucket of water close by to keep the temps down (even though you should never get that much color if you're doing it right)
Steve
Amateur knife maker...
I use a belt sander like that.
Steven Kubien
>I got the unit from Lee Valley (might be the same as Herman's) and put a motor on it. It's a little tricky setting up a Wolverine-type unit but once it's done it's great. I mounted a shroud over the top wheel with some rare-earth magnets in it to catch some of the filings. and to keep them from flying around. Not sure how much it helps but I feel better and clean less.
Steve Kubien
ET
>Randy, This is a great looking set-up. Where did you get the tool holder? ET
Dennis Daudelin
>Jon Siegel, a professional woodturner from New Hampshire has been selling a custom belt sharpening tool for many years! You can see his sharpening system on his website, www.bigtreetools.com
He's advertised it in More Woodturning for the last year or so too!
Dennis
(don't own one yet but sure would love to!)
Randy Privett
>I made them, their based loosely on the Sorby design.
Randy
