Finishing objects
Finishing objects
Steven Antonucci
Finishing objects
steve antonucci
>I thought I'd offer my system for holding hollowforms and see what folks do to finish bowls?
When I have a hollowform to spray or oil, I string a 25# test fishing line from overhead and tie a small piece of wood to the end. I then insert the wood through the hole in the hollowform, and spray/wipe/brush away. No finishing marks from sitting on a table or outside holding devices.
I've just started oil finishing bowls, and I'm trying to think of a way to do the same. So what do you do to hold a bowl while finishing?
Re: Finishing objects
Bill Hale / The Wood Spinner
>Steve
I use a lazy susan to do the work on. I put down a piece of plywood, size as required to set the work on. I use snall, 1/4 x 1/4 x 2" spacers and set the work on three of those. I do one side, let it dry and turn it over to do the second side. The spacers are for you get a good finish to the bottom and to allow the first finish to finish drying. That is for non oil finish. For Walnut oil I just slather it on a couple of times wipe it off and set aside on a ply board with the drying spacers.
In either case even if you do get a mark it is so small a touch with fine sandpaper and it is gone.Good turning and be safe
Bill in CG, AZ.
Frank J
>three dowles with points up, to set the bowl on inside or out side. no marks. I use a pencil sharpener to get clean even points on the dowles
Dennis Yoder
>Steve, I use metal plates with the small triangular cleats( can you tell I can't think of the real and proper name)used to join 2x4s in the lumber section of the borgs to elevate the forms about the turntable. Dennis Y
Steven Antonucci
A picture of the "hollowform hanger"
steve antonucci
Steven Antonucci
In action
steve antonucci
>This is a hollowform hanging from the thing. It's a 13" tall holly form that weighs less than 15 ozs. hanging from 2# test. I can give it a tiny bit of a spin, and spray around the whole form without touching it again.
Steve
Allen Neighbors
>I have several pieces of 2X that I drilled 1/8" holes in. I use three #6 finish nails, inverted, in any of the holes as necessary, to hold the piece upright for spraying with lacquer. This is set up on a small lazy susan to rotate as needed for spraying.
For oil finishes, I apply that on the lathe. Then do the bottom later by hand, when it's been finish turned.
For hollow forms, I invert them over a long dowel, also in a piece of 2X.
I like your idea of the fishing line with a stick. :)
