bell clapper
bell clapper
bell clapper
JohnKJordan in East TN
>Someone asked about a clapper in a bell orniment. The photo below is how I'm doing it. A length of wire is fastened between two tiny holes and twisted with a loose "eye" on each end to allow free movement. This clapper is of jatoba, the bell/handle is Pink Flame/Ebony.
I upgraded my bandsaw table photo studio with the recommended blue background. :)
Re: bell clapper
Mike Stafford
Re: bell clapper
Mike Stafford
>Just beautiful, John, I really like these and know that they will make wonderful gifts. Enjoyed seeing them a bunch!
Re: bell clapper
Re: bell clapper
Troy German
>Thanks John,
Those are beauties.
Troy
Re: bell clapper
Re: bell clapper
>John, Those are truly beautiful. I am impressed with you handle and clapper. I have never been able to reliably drill the holes in the end of the handle, so.... what I do is....
I turn the handle with a stepped tenon on the end. I have the collar that sits on top of the bell and a short but fairly large tenon that snugly fits in the hole in the bell and a smaller tenon that protrudes from that and is rounded off on the bottom. I drill a hole for the clapper through the smaller tenon. I either use a bead for a clapper or make one by drilling a hole through a small piece of wood and chucking it in a drill or on the lathe and sanding it into submission. For a hanger for the clapper I use a "pin" of soft brass wire. (from Michaels I think) the head of the pin supports the clapper and the other end goes through the hole in the tenon. Since the bead and tenon are smaller that the hole in the bell, you can assemble the clapper onto the handle and drop the clapper through the hole in the bell.
Re: bell clapper
Re: bell clapper
FWIW, I also always had trouble drilling concentric holes with a drill bit in the tailstock chuck - the bit would flex and wander and get started off center. Then I tried turning up the lathe speed real fast to start. So far, this seems to work better. I may also try a "center drill", a short combination drill and countersink - very rigid. Anyone ever try that?
