cupids ornament
cupids ornament
cupids ornament
>ere is an ornament I just turned. It is an inside-out turned maple ornament with a carved cherry heart inside. The heart is captured by 2 mahagony finials and has a yellow heart arrow captured in the heart that can move and rotate. This was fun to make. The arrow tip is carved and lightly textured with a woodburner and the feathers were burned also.
Re: cupids ornament
Re: cupids ornament
Ron McKinley
>O.K. John, tell us how you got the arrow through the heart! ....Ron
Re: cupids ornament
Re: cupids ornament
Troy German
><"O.K. John, tell us how you got the arrow through the heart!">
You know he's going to say "with a really small bow."
The ornament looks good. It looks like a tall man with a big heart and a small beret.
Thanks for posting,
Troy
Re: cupids ornament
really accurate shooting :)
>The arrow was flat, about 3/8 x 3/16 x 3" I chucked it up very carefully between my chuck and a live center. I turned the shaft with a smaller tenon in the center. I made sure that part A and part B were shorter than the width of the heart (part C) see the drawing. Then I parted it off so the tenon stayed with the half that went with the live center.
I used the point of a small skew to cut a center divot in the end of the arrow that was in the chuck. I chucked up the jacobs chuck and then center drilled the other part to the same size as the small tenon.
When it was all done I put some thin CA on the small tenon. inserted the parts in the heart and pushed them together. I've used this trick many times and it always fools people.
Re: cupids ornament
You had me fooled...
Ron McKinley
>thought you were playing Mervin with the Rosetta Stone...hope I got my characters right! GRIN
