Vari-Grind/Tru-Grind Questions
Tom Minehan
>I have one of the early Tru-Grind Systems. I find that as the gouge flute gets shorter the tool holder must be tightened on either the transition from the round stock to the flute or on the round stock itself. Neither of these is very secure as the tool then wants to wiggle. Does the Wolverine Vari-Grind Attachment suffer the same type of problem? Could the Vari-Grind Attachment be used with the Tru-Grind base? Maybe I should learn to grind "free hand" and be done with it.
