Bowling ball ....
Bowling ball ....
Bowling ball ....
Tim GC
>A 'good friend' has given me 3 bowling balls ... she wants a pen from each... can someone please explain to this dim witted Brit how to get into the damn things without the use of a nuclear air strike or at least a few ounces of C4!!
I tried dropping one out of a 3rd floor window.... just messed my concrete up and scratched the ruddy ball ...
Any and all suggestions welcome
Re: Bowling ball ....
Steven Antonucci
Chainsaw and an old chain for starters
steve antonucci
>outside, because I'm guessing it'll create a huge mess...
Steve
Rick Allen
>Mount it between centers and part the ball in half. At lease far enough so you can finish off the primary split with a handsaw. Then use a bandsaw to process the halves.
There are three basic types of bowling balls.
One has the same material all the way through.
The second type has a core material with a outer layer of the pretty "stuff". You should be able to inspect the finger holes to determine which type you have. If you have the second type you may be hard pressed to make an attractive pen.
The third is solid through but is unattractive on the outside as well as on the inside.
Re: Chainsaw and an old chain for starters
Bill Hale / The Wood Spinner
>Steve
just curious Why a dull chain?
Bill
Steven Antonucci
didn't say dull, I said old...
steve antonucci
>I have a few chains for my saw. Every once in a while when I suspect that there might be metal or other mess in a log, I'll use an old chain (still sharp) to reduce the risk of killing a new chain.
The one time I didn't, I managed to cut exactly three inches into a piece of ash before hitting about 20 nails and breaking half of the teeth.
So now, if I'm unsure about what I'm cutting, I'll put an old chain on the saw.
Steve
Scott Greaves in Blackfoot Idaho
>Tim,
You might be disappointed with what you find once you get the ball cut up. The balls are often layers of different materials, with the outer layer quite thin (in terms of pen-making material), and the inner layers quite bland. A better option is to buy a pen blank of bowling ball material from Pens Of Color (http://www.pocwoodworking.com/) and turn it from that.
Good Luck!
Scott.
Tim, try this... *LINK*
clem wixted
>...link for some info on using bowling balls for pen blanks. I have been looking for this type of information for some time and there isn't much available from people that have actually done it, and what is available is sketchy. This one is pretty good.
The only other information that could be added to the info on the link is that Ebonite will shine up real well if it is finished properly, even if it is hard to cut, which may be why it polishes well.
Clem
Try a google search using this link title and you will find some interesting information, most of which isn't very helpful, for what you want to do.
Using Bowling Balls for Pen Blanks
eaglesc
>It is possible,I did it three years ago.
I cut the ball with my bandsaw(you think logs are tough)
The blade was destroyed by what seemed to be a cement core.
Being a gamecock fan I didn't mind so much it was a ball with a clemson tiger paw on it.
It would be a lot easier if you found a commercial blank with the same colors and made the pens and threw the balls in the dump,or use them as gazing balls depending on how often your friend visits.
Those are not just glue lines, the tube is visiable
Dang... you gotta' want a pen...
DWR
>... out of a bowling ball something fierce to go to that much work!
Robert D. Macgregor
>My first thought was to use a large-diameter coring tool, but this would only work for a solid ball. I never knew the "good" part was just a veneer.
Thanks to all ... results posted soonest
Tim GC
