Oneway live center
Oneway live center
Oneway live center
wilbur
>My understanding is that the cone tip (as well as the large reversible cone) for the Oneway live center is made of aluminum. Would this make using the Oneway live center inappropriate for supporting the end of a pen mandrel? I would think that since the tip was made of aluminum instead of, say, tool steel, the tip of the cone could easily deform.
Of course, if the tip is made of something else, I'd be glad to be corrected.
Re: Oneway live center
Bill Hale / The Wood Spinner
>You do not put the cones on for this usage. The live center has a steel point base unit that the cones thread on.
Good turning and be safe
Bill in CG, AZ.
wilbur
>I thought the steel base was a cup center, not a 60 degree cone. Unless I'm mistaken, I thought the pointy part of a cup center has a more acute angle than 60 degrees, which also could lead to misalignment with a mandrel designed to accept a 60 degree center in the long run.
>Wilbur
The point in the cup is ok for the pen mandrel. All you do is to bring it up just tight enough to prevent the pen mandrel from moving.
I don't know what the angle is but it works for me.
Bill in CG, AZ.
Jim Pugh, Elyria, OH
>Actually Wilbur, you can go ahead and use the aluminum center in your pen mandrel. You will do more damage to the aluminum by knicking it with a tool during normal turning than while pen turning. And, if the end starts looking a bit gross, there is a way to smooth it back out. Years ago I was also concerned about damage to the small aluminum cone and asked Oneway if I could get a replacement if I ever needed it. They said "sure". Guess what, I'm still using that original cone - perhaps 10 years later.
Fog Tanner
>I tried using the aluminum cone for a pen mandrel. It did work, but I also had to get it returned on a metal lathe so I could use it. Messed the end up. I made a reverse cone out of wood, which is threaded to fit the Oneway live center. Bottom taps can be had at Wholesale Tool and worth having. I put the live center on my spindle with the cone on it. I used an allen wrench to lock the live center and held it in place with some electrical tape. I then trued the cone up with the center of the live center, so the pen madrel would run true. I have been using this method ever since, and can make another to fit any changes in mandrel's fairly quickly.
I have since made a number of other shaped "noses" for that live center for other speical uses, suck as jam chucking various shapes.
