bowl gouge
Julie
>here is a pic of the 3 bowl gouges I have.
Wondering if the need to be ground a different way. I cant seem to get the hang of the use of these. THought maybe a pic might help.
bowl gouge
Julie
Re: bowl gouge
Julie
>another pic
Re: bowl gouge
wilbur
>It's a bit hard to tell from the angle in the pictures, but it looks like that the tip of your bowl gouges are too flat, which usually is a result of spending too much time grinding the tip of the bowl gouge relative to the sides.
I did this when I was first learning to grind gouges. I found that you should spend much more time grinding the sides, and much less time on the tip than you think you need.
The one on the left isn't what I'm used to seeing?
steve antonucci
>I know that they sell them that way, but I've never seen anyone use them like that. You should regrind it to a similar profile to the other two. I'm guessing that you could cut with them if you had some lessons, but you'd probably regrind them based on the lesson.
Look in the righthand menu and you'll see the tools grind on the bottom to show what other folks use.
Steve
Re: bowl gouge
Wally Dickerman in Arizona
>The gouge on the left looks like a catch waiting to happen. There is a shoulder at the tip that will be trouble. The grind on the nose should be nicely rounded and the profile should be a gentle curve from the tip through the side grind. I suggest that you take a good look at the gouges in the grinds library. Pay special attention to the profiles. No high shoulder
Wally
Re: bowl gouge
Allen Neighbors
>Julie, I think the high shoulders are what's causing your problems.
Look over on the left side of your screen at the links. Under "Odds 'n' Ends", fifth link down... Tool Grinds Library. My gouges are ground pretty much like Terry Daniel's grind.
If you use a the Wolverine grinding jig, and a Varigrind, and want a grind pretty close to that:
The angle of my varigrind is set at 30 degrees. The nose of the gouge is extended through the varigrind 1-3/4". Next, Adjust the length of the Wolverine arm to where the nose bevel of your gouge is flat as possible against the stone. Make a small template that you can use to adjust it to this distance accurately every time. It'll be easier to set up.
Grind the side wings with gentle slope about 5/8" long on a 5/8" gouge. It will be a good place to start.
When you need to re-sharpen it, sharpen both wings first then touch the nose... or at least don't spend as much time on the nose as you do on the wings. Too much time on the nose will shorten it, making the wings have too steep of a slope to them, which will invite catches.
Just a suggestion. Hope it gives you a place to start.
Re: bowl gouge *LINK*
Gordon Seto
>This is a fool proof method.
If you use a Oneay Varigrind jig, down load and print out this pdf file.
Lay your jig over the full size picture and set your jig.
Shoot for the final shape as pictured. You will have a usable grind which is more friendly than you shown in picture.
How you use any particular grind is very important. If possible, find someone to show you would be my first choice.
Re: bowl gouge
Doug Thompson near Cleveland
>Julie, as it has been said before a bowl gouge needs wings to work. A 60 degree nose angle is a good starting point. Sharpen all 3 then take another picture.
>Julie The one in the middle is about right. I have one gouge that is a stewart Batty grind that I use a lot and it has about that angle. You will find that most people use a bowl gouge with the wings ground back further, and I do also. I would suggest getting the AAW DVD on sharpening. It covers several different ways sharpen a bowl gouge and is an excellent video.
Other than that I would strongly suggest getting the ONeway sharpening system with the Wolverine jig and then follow the instructions on Doug Thompsons site. You can still ruin an edge with the jig. The same principals of shaping an edge apply it just takes away some of the finesse that is necessary when hand grinding.
http://www.woodturner.org/products/videos/fundamental_sharp/
Re: Doug T. has really provided.....
Jamie Donaldson
>.. a wonderful service by posting this life sized Wolverine jig diagram and instructions for all to see, measure, and use as a no nonsense standard. It's much better than just trying to visualize from a worded discription like an instruction sheet. Thanks Doug- I have been recommending this diagram to my students as a refresher when they have questions about sharpening the bowl gouge.!
>I am so thankful Oneway allowed the picture to be used, that one picture is worth a thousand words. BTW - our own Joe Ott took the picture and I forgot to give him the credit. Sorry Joe...
I own 4 Vari-Grind attachments but the one in the picture is used all the time. Grinding wheels need to be replaced even the Dayton grinder needs bearings replaced but this jig shows no signs of wear.
