Re: sharpening scrapers
JohnKJordan in East TN
>BQ,
I use a Tormek to sharpen Sorby multi-tip scraper blades, fairly thin interchangeable tips which I'm guessing are similiar to the Crown. (I haven't seen the Crown)
I hold the tips on a flat rest set to about 80 degrees then hone the top lightly with a diamond stone. This puts a very fine grind on the curved edges. Then I raise a "burr" with a Veritas burnisher. This is a clever little device that attaches to a flat surface and burnishes with a tungsten pin. It works especially well on large handled scrapers, using a second pin as a fulcrum allowing more force, but also works fine with the small tips. I like it better than using a hand-held burnisher since it holds the angle constant for a more uniform edge.
Compared to a burr left by a grinding wheel, this will leave an incredibly smooth cutting edge which I think lasts longer. It can be either agressive or delicate depending on how it's presented.
