It depends on how you mean it
steve antonucci
>I sometimes need to cut "round stock" or half round too.
If it's really big (pushing the limits of my 12" saw), I'll use the chainsaw. Someone else mentioned this, so I'll second it.
Sometimes, I've processed the round into half round, and drawn a circle on the flat. Mark a straight line tangential to the circle to knock off the corner and send it through the bandsaw flat side down. No danger at all with this approach, since the table supports the wood throughout the cut.
If you must cut with the round side down, I hold the wood tightly and push/pull it through the cut from the right side of the saw. I have kinked a couple of blades, but my hands are nowhere near it when it happens.
I don't worry too much about perfect circles, since one pass with the bowl gouge can take 1/2" of imperfect away in a few seconds.
Steve
P.S If you are looking to saw logs along the length into lumber, that's another story. I've seen "cradles" to use for resawing, but I don't have one.
