Repairing water spotted wax finish?
>I made a wine stopper in the shape of an apple. Its about half the size of a real apple and hollowed so that one of Ruth's SS stoppers is up inside it. It fits down over the neck of the bottle. I Beal Buffed it and finished it with carnauba wax. Now it is water spotted from spending time near the sink and in the fridge. What now? Buff it again? Any suggestions on a new finish that will not be ruined by the existing wax and future water?
Re: Repairing water spotted wax finish?
Dick Coers
>Is there any finish under the wax? Paint thinner/mineral spirits will remove the wax. If there is a finish under the wax, lacquer thinner or stripper will remove that. I stopped using wax a long time ago on my pens and such, just not compatible with heavy use and lots of skin oil. I would suggest a polyurethane, or wipe on poly type of finish. It will be slow, takes several hours to dry and even more time if you want to buff out the finish with abrasive. If you want the high gloss, use micromesh sandpaper with up to 12000 grit, then maybe a plastic polish (superfine abrasive in a fluid).
Bill Hale / The Wood Spinner
>Wax.....NO NO NO. I like Dick quit using a wax as a finish a long time ago. I use Krylon Can spray on urithane that I buy from WalMart. No clean up just spray on let dry. Several coats and polish to what ever luster you like. Be carefull when you buff to not get the finish hot or it will be a mess. I wet sand with water.
I do sometimes use Minwax finishing wax ofer a finish just to attain a great feel.
Good turning and be safe
Bill in Casa Grande,AZ.
