Moisture Meter?
Jim
>I need help. I want to measure the moisture of my rough turned bowls.
What should I use and what should the moisture content be to finish turn? I'm looking at some cheap two pronged testers. Anyone ever use them? Thanks.
Moisture Meter?
Jim
Re: Moisture Meter?
Jim Terry
>I am using one I purchased from the local Klingspore Woodworking Store. It is a small digital readout that cost about $70. Not cheep but cheeper than some. The brand name is Moistec. As far as what level you should achieve probably depends on your local climate. In my shop here in NC I like to get down to 10 or 12%.
Re: Moisture Meter?
Walter Ahlgrim
>How will knowing the percentage moisture content of your wood help you? All you real want to know is that your wood is at equilibrium with your environment. That could be 3% in Arizona or 20% in Louisiana. You will find different species of wood with the same moisture will have different readings. I weigh my blanks when they stop losing weight they are dry enough. A scale like ebay item 150184177738 works well for me.
Walta
Re: Moisture Meter?
>I'm kinda on the fence here. I would really like to have a moisture meter so that I would know what the moisture is. Why. Just interested I guess. I don't think it will change the way I work. I don't think a pin type meter would work for me because I don't want to poke holes in bowls however the pinless meters don't seem to have the same reputation as the pin readings. Of course I'm would just be using it mostly as a reference of to read that odd piece of wood that the neighbor gives me and I don't have any way of knowing how dry it is.
Re: Moisture Meter?
Keith Newton
>I have both the pin, and pin-less, but I never use either for any part of my turning. Almost all of my turning wood is green, and cheap meters won't help you here. I think that they are only accurate below 20% MC.
As for using the pin-less for reading the mc of a finished turning, I am not sure that you would get a good reading if the thickness is less than half an inch, and most of mine are well below that thickness.
Re: Moisture Meter?
ebd
>I've been using the cheap ($30ish) pin type meter from Woodcraft for years. It is quite useful. I can't say for sure that it tells the EXACT moisture content. That information is useless to me. However it DOES let you know what the initial (wet) reading is and when the wood has dried to as dry as it's going to get. It does it far faster and easier than weighing. If the one I've got breaks you can be sure that I'm going to get another. It has allowed me to finish turn wood that dried faster than I expected and wait for wood that I thought must be dry. I've also purchased wood that I was assured was dry and when I checked was nowhere near dry enough to turn without tempting fate.
Re: Moisture Meter?
Dave Belser
>I bought a pinless meter because I wanted to know the moisture level on flat stock I use in building up tubes. It was worthless on bowl blanks, mostly because there is no flat place to test! The face of the pinless meters is about 1 x2.5 and needs to sit flat on the wood.
I agree with the above comments, If really am concerned about moisture content in a blank, I weigh it daily on a high resolution digital kitchen scale (about $30). I usually just write the weight and date right on the blank but have gone as far as keeping a spread sheet and building graphs from the data. This is a good exercise if you want to get a better feel about how wood drys out.
The blank is "dry" when the weight stabilizes and moves up and down a gram or two a day.
- Dave
Re: Moisture Meter?
Ralph
>Harbor Freight is your friend...
I generally agree with many/most/all of the comments already made.
I use a Harbor Freight two pin meter (95696) that I got on sale for $10 (regular $20). I don't rely on the number, but rather when the reading stops changing.
I also use a HF scale (95364), that I got on sale for $15 (it's currently on sale0
Re: Moisture Meter?
Mike Jones
>I use a Wagner and a postal scale. The MM can tell me the difference between areas of my blank, (e.i. end grain vs.side grain, heartwood vs. sapwood, etc.) the scale cannot do that. Occasionally, that is important. (I have had some rough-turned pieces that the scale indicated 'dry', then had some blushing show up in the finish due to pockets of moisture.)
Your moisture meter can tell you the 'ambient' MC for your area. Test the woodwork in your house...take it to the lumber yard and test the kiln-dried lumber. That will give you a 'target' MC to shoot for.
Using both methods has helped a lot in learning about drying.
